Old 03-11-2013, 02:26 PM   #1
ron hebb
Default aluminum heads
how may years did they produce 21 stud head in aluminum with out lets in center
thanks ps could some one tell me the years
ron hebb is offline   Reply With Quote
Old 03-11-2013, 02:48 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: aluminum heads
Well, thay only made that engine one and a half years 37 and early 38, late 39 came out with the 24 stud. I know 37 had both aluminum and cast iron heads, I don't know about the early 38 but I wouldn't doubt thay have both. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-11-2013, 03:01 PM   #3
ron hebb
thanks for that walt
would those heads fit on any 21 stud engines
Old 03-11-2013, 06:50 PM   #4
Walt Dupont--Me.
I believe thay would because people have used the 32-36 water pumps in the heads on the 37 engine and block off the front water pump holes. BUT, if you use the 37 heads on an earlier 32-36 block, what are you going to use for water pumps? Walt
Old 03-15-2013, 01:48 PM   #5
ron hebb
plan on the truck pumps with the mounts on them.
had them done at skips in fl.
Old 08-26-2014, 06:39 AM   #6
oll37
Late but anyway.
The al heads were discontinued mid feb 1937, so they only lasted for the first months of production of the -37.
Lennart,
Sweden
oll37 is offline   Reply With Quote
