Old 07-19-2012, 05:18 PM   #1
Ed in Maine
Default Installing Radius Rod Rubber Ball
Today I put the rubber ball on the freshly painted radius rod/front axle. After about 45 minutes of trying to get the ball to go on with a little liquid soap, I felt there had to be an easier way. There is! I took a plastic bottle and cut out a cone shape. The small end goes into the rubber ball and the large end goes over the radius rod ball. Just push, the cone opens the rubber ball equally all around and it easily goes over the steel ball. Before it goes on all the way, take out the plastic cone. It worked the first time in less than a minute. Ed
Old 07-19-2012, 08:23 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Installing Radius Rod Rubber Ball
How often does that rubber need to be replaced? I know rubber and oil don't coexist too well.
Old 07-20-2012, 08:55 AM   #3
AlanD
Neat idea, like a shoe horn, but cone shaped
AlanD is offline   Reply With Quote
Old 07-20-2012, 10:03 AM   #4
Napa Skip
Napa Skip's Avatar
If similar to Snyder's a-3436, the "rubber" ball is actually made of neoprene and should give good service in an oil environment. (This is not meant as an endorsement or recommendation of the neoprene ball over the original installation.)
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Last edited by Napa Skip; 07-20-2012 at 10:25 AM. Reason: add caveat about not recommending one or the other installation
Napa Skip is offline   Reply With Quote
Old 07-20-2012, 10:15 AM   #5
CarlG
CarlG's Avatar
When I bought my truck, it had the "rubber" ball on it. It was totally mush from being soaked in oil. I replaced it with the original type unit and have not had any problems with it. Steers better too!
Old 07-20-2012, 10:21 AM   #6
Dave in MN
Dave in MN's Avatar
Two spoons also work as a tool to work it over the ball.
Dave in MN is offline   Reply With Quote
Old 07-20-2012, 10:29 AM   #7
Brent
Brent's Avatar
I'm not "seeing" what you're writing about. Do you have a pic of the cone?
Brent is offline   Reply With Quote
Old 07-20-2012, 10:33 AM   #8
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I used to turn the rubber insde out and just push it over the steel ball. I no longer use the rubber ball and have goneback to original.
Barry B./ Ma. is offline   Reply With Quote
Old 07-20-2012, 10:34 AM   #9
Mike
Mike's Avatar
I would not use the rubber ball setup, call brattons and get the original radius rod set up
Mike
Mike is offline   Reply With Quote
Old 07-20-2012, 01:27 PM   #10
HoarseWhisperer
HoarseWhisperer's Avatar
I had the same experience with my truck. Better steering and no wobble with original radius caps set properly.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 07-20-2012, 01:58 PM   #11
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
why do you have the rubber ball to begin with??? why not fix the original ball to start with?
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 04-09-2021, 07:02 PM   #12
burner31
burner31's Avatar
This is a strong contender for the top 10 list of tricks and tips.
After messing with that rubber ball for 45 minutes, using everything I could think of and inventing several new cuss words I came upon this old thread.
Good job Dave, thank you, less then a minute I had that accursed ball in place, and Mama wasn't even mad about the greasy spoons.
Forget everything else...use the spoons (teaspoons that is)
Keith
Shawnee OK
'31 SW 160-B
Old 04-09-2021, 08:29 PM   #13
Pete
Pete's Avatar
There is no rubber ball on mine. I cut the whole front end off my A and installed a Mustang clip.....LOL. (not really, I am just messing with you)
Old 01-14-2022, 06:50 PM   #14
twostickmutt
curious as to how you used the spoons.
twostickmutt is offline   Reply With Quote
Old 01-14-2022, 09:56 PM   #15
Synchro909
Synchro909's Avatar
Like this. https://www.youtube.com/watch?v=hi7-ipIwVeM
Old 01-15-2022, 10:05 AM   #16
Robbie1
Robbie1's Avatar
Originally Posted by Synchro909 View Post
I can't believe I watched the whole thing
Robbie1 is offline   Reply With Quote
Old 01-15-2022, 10:10 AM   #17
Kevin in NJ
Originally, for the later Fords that used the rubber, there are a pliers things that opens the hole so you can put them on.
I have one in my tools.
For the A you really should not use one as there are options to allow you to use the original.
Old 01-15-2022, 10:14 AM   #18
old31
Well, I watched about 10 seconds and enough.
https://www.youtube.com/watch?v=bRMbv14lkLM
old31 is offline   Reply With Quote
Old 01-15-2022, 12:31 PM   #19
burner31
burner31's Avatar
This is the best and fastest way that I have found, every Model A man should have two spoons in his tool box, if not for putting on the balls then to get people to ask "What are the spoons for" Use your imagination for the answer.
Keith
Shawnee OK
'31 SW 160-B
Old 01-15-2022, 02:48 PM   #20
Benson
Benson's Avatar
wrong post sorry
