07-19-2012, 05:18 PM | #1 |
Installing Radius Rod Rubber Ball
Today I put the rubber ball on the freshly painted radius rod/front axle. After about 45 minutes of trying to get the ball to go on with a little liquid soap, I felt there had to be an easier way. There is! I took a plastic bottle and cut out a cone shape. The small end goes into the rubber ball and the large end goes over the radius rod ball. Just push, the cone opens the rubber ball equally all around and it easily goes over the steel ball. Before it goes on all the way, take out the plastic cone. It worked the first time in less than a minute. Ed
07-19-2012, 08:23 PM | #2 |
Re: Installing Radius Rod Rubber Ball
How often does that rubber need to be replaced? I know rubber and oil don't coexist too well.
07-20-2012, 08:55 AM | #3 |
Neat idea, like a shoe horn, but cone shaped
07-20-2012, 10:03 AM | #4 |
If similar to Snyder's a-3436, the "rubber" ball is actually made of neoprene and should give good service in an oil environment. (This is not meant as an endorsement or recommendation of the neoprene ball over the original installation.)
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. Last edited by Napa Skip; 07-20-2012 at 10:25 AM. Reason: add caveat about not recommending one or the other installation |
07-20-2012, 10:15 AM | #5 |
When I bought my truck, it had the "rubber" ball on it. It was totally mush from being soaked in oil. I replaced it with the original type unit and have not had any problems with it. Steers better too!
07-20-2012, 01:27 PM | #6 |
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
07-20-2012, 10:21 AM | #7 |
Two spoons also work as a tool to work it over the ball.
04-09-2021, 07:02 PM | #8 |
This is a strong contender for the top 10 list of tricks and tips.
After messing with that rubber ball for 45 minutes, using everything I could think of and inventing several new cuss words I came upon this old thread. Good job Dave, thank you, less then a minute I had that accursed ball in place, and Mama wasn't even mad about the greasy spoons. Forget everything else...use the spoons (teaspoons that is)
01-14-2022, 06:50 PM | #9 |
curious as to how you used the spoons.
01-14-2022, 09:56 PM | #10 |
Like this. https://www.youtube.com/watch?v=hi7-ipIwVeM
01-15-2022, 10:05 AM | #11 | |
01-24-2022, 07:59 AM | #12 |
Good one with the spoons!
01-15-2022, 12:31 PM | #13 |
This is the best and fastest way that I have found, every Model A man should have two spoons in his tool box, if not for putting on the balls then to get people to ask "What are the spoons for" Use your imagination for the answer.
07-20-2012, 10:29 AM | #14 |
I'm not "seeing" what you're writing about. Do you have a pic of the cone?
07-20-2012, 10:34 AM | #15 |
I would not use the rubber ball setup, call brattons and get the original radius rod set up
Mike |
01-24-2022, 06:59 AM | #16 |
01-24-2022, 10:57 AM | #17 |
Just a steel ball, you can weld up worn spots and file back to a somewhat round shape.
"The more things change, the more they stay the same." |
07-20-2012, 10:33 AM | #18 |
I used to turn the rubber insde out and just push it over the steel ball. I no longer use the rubber ball and have goneback to original.
07-20-2012, 01:58 PM | #19 |
why do you have the rubber ball to begin with??? why not fix the original ball to start with?
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
04-09-2021, 08:29 PM | #20 |
There is no rubber ball on mine. I cut the whole front end off my A and installed a Mustang clip.....LOL. (not really, I am just messing with you)
