10-03-2017, 07:08 AM | #1 |
Is there a replacement for Ford shock fluid?
What can be used to refill Houdaille shocks? Motorcycle fork oil? ATF?
It's really a pain to get it shipped overseas so I hoped for a more common replacement. Any ideas? |
10-03-2017, 07:33 AM | #2 |
Re: Is there a replacement for Ford shock fluid?
This link covers the topic:
https://www.fordbarn.com/forum/showt...ight=houdaille I could not tell for sure what was in my '41 shocks. I used hydraulic jack oil about a month ago, and so far, so good. |
10-03-2017, 08:32 AM | #3 |
I was looking too and found a test of motorcycle fork oil, atf tested as good or better as most fork oils, but is thin, depending on the wear in your shock thicker oil may be needed, I put atf in my model a shocks, ---
10-03-2017, 11:15 AM | #4 |
10w forkoil is real close to hydraulicoil 32 which is often sold as jackoil....
I used 10w straight oil that we use for converters on the heavy equipment that worked fine...Stiffer oil gives you a tuffer shockabsorber...depends on if youre going racing or not. |
10-03-2017, 11:39 AM | #5 |
I used straight 20wt. Oil in my loader hydraulics on my Ford 8n for over 10 years, never had an issue.
10-03-2017, 09:34 PM | #6 |
"The correct oil for Bills and my rebuilds is gear oil 85-140w or as close as you can get. I recommend putting a little sealer on the fill plug when tighten it. I use permatex #2 form a gasket"
10-05-2017, 01:41 AM | #7 |
Thanks everybody for your input! I decided to use fork oil.
