07-04-2019, 11:43 AM | #1 |
need help - carb leak
Can somebody help me? My newly installed Ford 94 carb is leaking at the accelerator pump link rod. What can be the problem?
07-04-2019, 11:48 AM | #2 |
Re: need help - carb leak
Float set too high, needle not closing off fuel flow or too much fuel pressure. Is it dripping inside throat venturis?
07-04-2019, 11:58 AM | #3 |
I have a pressure regulator, so that shouldn't be the problem. I set float level as per Ford manual - air horn upside down, measuring from the bottom of the float to the gasket surface 1 3/8 - 1 11/32. Is that correct?
Dripping with engine running? |
07-04-2019, 12:34 PM | #4 |
Check the carb float. Shake the brass type to see if it contains fuel. If it is the plastic type, replace it. Either type will cause the float to drop, allowing overflow. In the case of the plastic type, alcohol fuel will infiltrate the float. Virtually all gas today contains alcohol. Even if the pumps say no ethanol, the pump and hose still can hold it if the last user bought gasohol.
07-04-2019, 04:00 PM | #5 |
There should be no fuel in the pump shaft cavity, so somehow it is getting in there. If you shut the car off with no air cleaner look into the carb and see if it is dripping fuel down the venturis. Have you checked actual fuel pressure? |
07-04-2019, 04:17 PM | #6 |
Just my two cents worth. Sal |
07-04-2019, 05:30 PM | #7 |
Sal, Felt seal is to keep dirt out of cavity, no fuel should be in that part of carb. Might be a porous casting.
07-05-2019, 10:24 AM | #8 |
Angledrive, fuel in the bowl can easily spill over on top of the pump rod when the fuel sloshes in certain circumstances in 94 type carbs. Especially if the fuel level is too high. In my opinion the felt seal isn't to keep dirt out, especially at the bottom.
Sal |
07-05-2019, 02:31 PM | #9 |
Sal, I guess it could, just never have seen that happen. Seems funny to me they would use a felt seal to stop fuel.
07-05-2019, 04:59 PM | #10 |
That's why I thought the seal was used to lube the pump rod. With a few drops of oil when assembled. Who knows ? Probably only the dead engineer that designed it.
Sal |
07-06-2019, 01:57 AM | #11 |
You mentioned a regulator. All are not perfect.
All carbs leak "some" if you use them for yrs and yrs. Or at least a little over time, if you drive them and not polish after ever show. Not that I've seen a clean carb on a old engine. Not to say you don't have an issue. . Last edited by Tinker; 07-06-2019 at 02:02 AM. |
07-07-2019, 06:49 AM | #12 |
Thanks guys for the input!
It looks like fuel level problem. I had an extra brass float lying around so I decided to switch floats. There was no fuel sloshing inside the old one but to my surprise the floats weigh differently, They are almost the same size but the new one is lighter than the old one. Unfortunately I didn't have scales to measure exact weights but I could feel the difference for sure. So, remembering physics, I decided to install the lighter float since it would give me lower fuel level. It worked! I still have some drops from a pump rod but now as much as it used to be. Now my next question: what are the symptoms of having too low fuel level? |
07-07-2019, 08:59 AM | #13 |
I think you will find it will seem to run out of fuel at speed.if you notice this then slowly ease off the throttle and you will notice it pickup speed.do you have a gauge in conjunction with regulator? if not I would question the accuracy of regulator1/2 to 1 lb will make a difference
07-08-2019, 02:02 PM | #14 |
thanks a lot!
my battery has dies so now i'm waiting for a new one. 6 volt battery is not an easy one to get in russia |
