12-05-2020, 01:18 PM | #1 |
55/56 Ford front bumper license plate holder
In 55/56 passenger car , did Ford have a bracket or holder for the front bumper to fix the front license plate? Or did the license plate bolt directly to the bumper ?
If so . is the bracket being reproduced by anybody ? |
12-05-2020, 03:02 PM | #2 |
Re: 55/56 Ford front bumper license plate holder
I glanced at a few '55 full-sized car photos online and they seemed to have slots in the center of the bumper for directly mounting a license plate. The holes were slotted to allow for different width license plates.
I have an original '55 plate for my '55 Bird and it's almost 2 inches wider than a current 'standard' size plate. The '55 plate mounting hardware at the rear was usually adjustable for a larger size also. Last edited by dmsfrr; 12-06-2020 at 01:39 PM. |
12-05-2020, 06:09 PM | #3 |
Very nice 1955 Ford Fairlane Sunliner. I believe that only slots were provided, as per photo posted by dmsfrr. |
12-05-2020, 09:34 PM | #4 |
54's had no front license plate bracket. Bolted direct to the bumper. Since the bumper comes to a point in the middle, the plate bends. I put some small spacers behind the plat to keep it straight
12-06-2020, 01:20 AM | #5 |
12-06-2020, 10:16 AM | #6 |
12-06-2020, 09:06 PM | #7 |
12-07-2020, 10:40 AM | #8 |
in short it is aftermarket.no biggy I made one for mine as bent plate did not do it for me and I sure others did (do) same.
12-12-2020, 09:41 PM | #9 |
I'd like to find a mount like evintho's. I've been looking for years with no luck. I have some perfect vintage plates but I've never mounted the front one. I just don't want to damage a 65 year old license plate.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic |
12-13-2020, 09:35 PM | #10 |
If your bumper comes to a point like the 54's did, then spacers between the plate and the bumper cures the bent plate problem
12-14-2020, 11:01 PM | #11 |
I've usually got some 1/8 or 3/16" inch aluminum plate around, something hard that won't bend. I've made a lot of backing plates for license plates by tracing the frame onto the aluminum plate and cutting it off (band saw, jig saw, belt sander to round the corners). Then any bracket will mount the aluminum plate to the bumper, and the frame and license plate mounts to it. Let's me set the height as I want it. It's a little work, but I keep cars for a long time. It doesn't stop chips, but stops larger debris and small impacts from bending the whole works.
I've made spacers out of oak and painted them. Wish I had a mill, but who doesn't. Last edited by miker98038; 12-14-2020 at 11:06 PM. |
12-15-2020, 12:45 PM | #12 |
I used round rubber thingies about 5/8 thick. I have no idea what they were meant for, Used the same ones for the 21 years I owned the 55.
12-16-2020, 09:54 PM | #13 | |
I've thought about rubber spacers, sort of like rubber bushings but they needed to be thicker that anything that thick laying around.
12-17-2020, 01:39 AM | #14 |
12-17-2020, 11:11 AM | #15 |
I don't think it would work unless the angled parts were bent a bit more. I was actually thinking the front license bracket for a Continental MKII might work. There seems to be repops available.
12-17-2020, 08:24 PM | #16 |
I used nylon spacers that I got a the hardware store. Angled them a bit to closer match the bumper.
12-17-2020, 09:30 PM | #17 |
My Front Plate was mounted directly....
12-17-2020, 09:52 PM | #18 |
Close-up photo of the Slotted Holes in the front Bumper of the 1956 Fords. It does not appear that there was an extra Bracket, or else the Holes would not have been Slotted? |
10-06-2022, 06:02 PM | #19 |
Reviving an old thread.
Using the picture from post 15 I made one for a lot less than what the repops are selling for. First the pattern for the frame. I cut it from a piece of scrap heavy gauge steel left over from floor pan replacement. A couple of bends using a pair of pliers, a propane torch and a vice. Installed the front and rear bolts, did a couple of spot welds to hold them in place. Added a stainless frame from O'Reilly. Works for me.
'54 Skyliner. Restoration in progress. |
10-06-2022, 06:29 PM | #20 | |
Everybody is going to beat your door wanting you to make them one ...
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
