08-12-2014, 05:47 PM | #21 |
Re: LEDs
I've been checking the catalogs looking for a 6v 10 watt cowl light bulb......is there such a thing? Thanks.
Dave |
08-12-2014, 05:57 PM | #22 | |
Re: LEDs
The catalogs show 3CP and 10CP bulbs. I haven't looked up the wattage for them yet. My cowl lights have #53 bulbs, haven't checked their muscularity yet. I have a feeling that the electronic 33 series 3 pin flasher that the vendors handle just may work for what I'm wanting to do. It appears these flashers may not care much about voltage. If I get this mess worked out, I'll post it. Heck, I'll post it if I don't. |
08-12-2014, 06:24 PM | #23 |
Re: LEDs
I wonder if the 12v electronic flashers care about polarity......if they do, wonder what happens when you plug them into a + ground system?
08-12-2014, 06:31 PM | #24 | |
Re: LEDs
Hmm, good point. If it turns into a waste of $12 for a burnt up flasher, maybe I'll turn the battery around and try again. |
08-12-2014, 08:15 PM | #25 |
Re: LEDs
I just ordered a pair of EF33's from an outfit called autotoys.com........if I fry one, I'll let you know.
08-13-2014, 12:23 PM | #26 |
Re: LEDs
After the accident I decided to brighten up the rear by installing LEDs. I thought I'd get state legal and install red lens so I ordered the complete tail light assemblies since it appeared easier and cheaper. There is a jumper lead between the two LEDs in each assembly. This lead needs to be clipped which is not mentioned with the lights or they will operate together. The cowl lights are used along with the parking lights for the fronts. 3CP were in the cowls. No numbers on them except for the CP. I installed 10 watt bulbs in their place. There was nothing on those bulbs except for made in china and 10 watt. No number or CP. There are more than 3 CP though/brighter. Everything works, almost. Turns are through a Signal-stat 900. The only 3 pin flashers I happen to have are #535 thermal's. The lights will start to flash once the flasher warms up which takes a minute or so. The lights operate differently with different 535 flashers. I did not try to add a resistor or extra bulb, I'll try another flasher first. I'll try to find locally an electronic 33 series 3 pin flasher. That seems to be about the most forgiving one if the spec sheet is to be believed. I'm trying to figure out if they are actually polarity sensitive. These rear lights are considerably brighter than the originals, but, don't look right. I guess there is always a trade-off. Hopefully they are safer. Sorry for being long winded. |
08-17-2014, 06:38 AM | #27 |
Re: LEDs
I have confirmed that the suggestion to use "10 watt bulbs" in the cowl lights should have referred to: "10 cp bulbs".
08-17-2014, 10:23 AM | #28 |
Re: LEDs
So far, the 260/535 thermal flasher is the way to go. Some extra resistance is/may be needed in the form higher CP/ wattage bulbs for the fronts.
I've yet to find an electronic flasher that will work and am running out of patience. Plus I could be buying a lot more beer for what those flashers cost. |
08-17-2014, 10:57 PM | #29 |
Re: LEDs
[QUOTE=Patrick L.;927016]..........
These rear lights are considerably brighter than the originals, but, don't look right. I guess there is always a trade-off. Hopefully they are safer. ....QUOTE] I agree Patrick I installed some recently and yes they where slightly brighter (my auto electrician upgraded the bulbs to something much brighter last time he did something to the car) but I couldn't live with the appearance of the LEDs it just looked way wrong to me ! Given in my case my bulbs were almost as bright I went back to them -Karl |
