Old 05-24-2021, 04:34 PM   #1
50FlatheadVert
50FlatheadVert's Avatar
Default Optima 6V Battery Mounting Options
Hi All,
New to the forum. I have a 1950 Custom and I recently purchased an Optima 6v battery for it after the previous battery soiled itself. I've been looking for options that will mount in the stock location (the car is stock and I don't want to drill any holes but I want it to look clean. The options I've seen out there appear to be more geared towards hot rods (shiny billet etc), I'd like something low key. I love the one below but mounting will be a challenge.
https://www.hotrodsbydean.com/produc...-battery-hold/
Thanks, Brian
50FlatheadVert is offline   Reply With Quote
Old 05-24-2021, 04:57 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Optima 6V Battery Mounting Options
Check out this thread-------
https://www.fordbarn.com/forum/showt...a+battery+case
Old 05-24-2021, 04:58 PM   #3
tubman
tubman's Avatar
You can buy an empty case with a top cover and put the Optima in it. The posts stick up in the corners, and with the top on, it looks like a stock battery. I got mine on eBay. It worked fine but it cost more than it should have in my opinion.
https://www.ebay.com/itm/29418887030...oaAut2EALw_wcB
There have been guys who get an old 6 volt battery, gut the case, make a top and run that way.
I can get you a picture of mine if you want to see it.
Old 05-24-2021, 05:07 PM   #4
Newc
Newc's Avatar
I have a 6V in my 53 and all I need was a block of wood to take up the diff. Newc
Old 05-24-2021, 05:20 PM   #5
50FlatheadVert
Those are interesting options thanks...does the battery move around in the case or is it mounted within the case?
Old 05-24-2021, 05:24 PM   #6
50FlatheadVert
tubman if you have a picture handy that would be great
Old 05-24-2021, 06:32 PM   #7
tubman
tubman's Avatar
There's an Optima in there. It fits snuggly when inserted diagonally, and I never had to use any spacers or anything.
Please excuse the mess; the trees up here are in full rut.
Old 05-24-2021, 06:56 PM   #8
Anteek29
Anteek29's Avatar
Very cost effective...Hope you painted the wood block black?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 05-24-2021, 07:21 PM   #9
50FlatheadVert
Thanks for the pics tubman!
Old 05-24-2021, 09:49 PM   #10
Emmit51
Emmit51's Avatar
I used a block of wood, like Newc
Tubman’s solution looks good, but agree price is a bit too much
Emmit51 is offline   Reply With Quote
Old 05-24-2021, 10:00 PM   #11
Tinker
Tinker's Avatar
Aesthetics vs functionality. Both work.
Old 05-24-2021, 10:10 PM   #12
tubman
tubman's Avatar
I was at my FLAPS last year and saw that someone had traded a repop Ford Script battery in. I bought it for 8 bucks (core value).
When I feel like doing a dirty job, I plan of gutting that case and using it with my existing top. This is obviously a cheaper and better solution.
Old 05-25-2021, 07:21 AM   #13
50FlatheadVert
Yes the Ford script battery would be ideal...I'm curious if anyone in the states offers one
Old 05-25-2021, 08:06 AM   #14
tubman
tubman's Avatar
Since no one rebuilds batteries any more (that I am aware of), there have to be a bunch of them floating around out there. The problem is finding one and then having it shipped to you.
I seem to remember that someone used to offer them, but when I looked, no luck.
Old 05-25-2021, 08:55 AM   #15
50FlatheadVert
I saw another post that said you should have a hole in the case to let the Optima breathe...has anyone had an issue with that?
Old 05-25-2021, 10:34 AM   #16
whizzernick
whizzernick's Avatar
see 12/22/20 search optma battery box
whizzernick is offline   Reply With Quote
Old 05-25-2021, 10:45 AM   #17
fordwife
There is a certain size of military ammo. can, I believe its 7mm. that a 6v optima will fit in, Check with a military surplus store.
fordwife is offline   Reply With Quote
Old 05-25-2021, 12:41 PM   #18
tubman
tubman's Avatar
If you look at the size of the holes for the battery posts on he eBay item and also consider that the top is a rather loose fit, I don't think extra venting is necessary. On mine, I use those green and red felt "post washers" to cover up the large holes.
Old 05-25-2021, 09:35 PM   #19
50FlatheadVert
if need be I can put a few holes on the fender side which won't be visible
Old 05-26-2021, 04:24 PM   #20
Wrenchead
Harbor Freight also sells ammo cans.
Wrenchead is offline   Reply With Quote
