Old 03-03-2019, 10:15 PM   #1
Karl
Karl's Avatar
Default Stromberg 48 Float setting
Could someone please advise the correct float setting for the 48 Stromberg.
Foolishly I let one of my friends clean out a carburettor for me and they decided they would take the opportunity to reset the float level. Need to return it to spec-Thanks Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 03-03-2019, 10:28 PM   #2
uncle max
uncle max's Avatar
Default Re: Stromberg 48 Float setting
Float level: Measure down 9/32" from the outside body gasket surface to the top of the free end of the float, just adjacent to the hump. Bend the tang accordingly.
When finished, it will be slightly lower than level.
This usually gives the magic 15/32" Fuel level.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-04-2019, 12:49 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Thanks for posting this Max. Would we use this same procedure for setting 40, 97, and 81 Stromberg Carbs?
John
Old 03-04-2019, 12:33 PM   #4
uncle max
uncle max's Avatar
Yes, LZ's too.
Old 03-05-2019, 04:14 AM   #5
Karl
Karl's Avatar
Thanks Max
You did the 48 originally and it is fantastic
I was so upset when my friend decided to reset things
Karl
Old 03-05-2019, 04:28 PM   #6
Ian NZ
Ian NZ's Avatar
I had trouble with seepage from the three bottom plugs on my Stromberg 48 and I fitted nylon washers on them and that fixed that. Place a little bit of gasket goo on threads 'only' on the small brass screw. Refer to previous thread on this subject.
Ian NZ is offline   Reply With Quote
Old 11-03-2020, 09:41 PM   #7
Ian NZ
Ian NZ's Avatar
Uncle max says measure down 9/32" from the face of the gasket surface to the top of the free end of the float opposite the float needle just adjacent to the hump on top of the float, to get the float level 15/32" to the fuel level from the gasket surface. Where should the float be, What does he mean, I cannot get that measurement on a Stromberg 48 carburettor.
Old 11-03-2020, 10:30 PM   #8
Charlie ny
FUEL LEVEL>>>>>>>>>>>>>>>>FUEL LEVEL
Charlie ny
