05-17-2021, 06:55 PM | #1 |
1935 Turtle Gear tooth Count
For our 1935 Ford, what is the correct number of turtle gear teeth. Is 19 or 20 teeth with 16" tires
05-17-2021, 07:00 PM | #2 | |
Re: 1935 Turtle Gear tooth Count
05-17-2021, 08:23 PM | #3 |
It is a 9:34 pinion/gear ratio
05-17-2021, 08:36 PM | #4 |
OK, look in the first column (9:34 = 3.78), rows 11 & 12 = 16" Tire Results in a #19 Turtle (19 Teeth) w/6.00 X 16" Tire DD |
05-17-2021, 09:09 PM | #5 |
Be sure when you select your part that you actually count the number of teeth instead of just going by what the number on top of it says. The gears can be replaced. I substituted a different gear number on my pickup and marked what it is on the case with a paint pen, but not everyone might not have gone to the trouble.
05-17-2021, 09:54 PM | #6 |
05-18-2021, 12:06 AM | #7 |
Mr flathead34, if you have a hankerin to play with old fords, you should buy the "green bible" all info for parts interchange up to 48 is there. Tons of fun, available in reprint
