09-04-2014, 01:24 PM | #1 |
Where can I get a Winfield Carburetor rebuild kit? Barry Bowyers?
I've tried contacting 2 numbers for Barry Bowyer who I am told makes Winfield carb rebuild kits. And an email for someone I am told makes rebuild kits, but have not heard back. Does anyone know who or where I can purchase one or two of these? I tried to fire up my built Winfield banger It has a very nice unrestored S downdraft but it has been sitting for some time and it is leaking fuel from the top of the bowl. Pulled it apart and the gasket is disintegrated.
Any help would be great. Thanks Matt
Matt in Seattle |
09-04-2014, 03:18 PM | #2 |
Re: Where can I get a Winfield Carburetor rebuild kit? Barry Bowyers?
Try Sammy at Arizona Model A
480 782 0266 In stock last time I asked Regards Juggs |
09-04-2014, 06:36 PM | #3 |
Someone on the HAMB will have the answer check the thread with the Monthly Banger Meeting heading. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
09-04-2014, 07:31 PM | #4 |
If you have a printer/scanner take the old gasket and make a copy of it. Draw in any missing parts. I found I can run paper board about the thickness of what is used in shirts and such through mine, the gasket for the bowl would be thinner anyway. Get some gasket stock the correct thickness and cut a square out. It comes rolled up so try and flatten it as much as possible. Fill in the areas of the copy of the gasket that you copied for your master. You will have a black on white copy of your gasket. Print a copy onto the gasket material and cut it out.
Or you could after filling in any missing parts rubber cement the copy to the gasket material then just cut it out. |
09-04-2014, 08:14 PM | #5 |
Even easier to just put a light coating of grease (Lubriplate, maybe?) on the part, press it down on the gasket paper leaving an impression to trim to.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
09-05-2014, 02:29 AM | #6 | |
On a heavy duty part, like the tranny top, you can tap the sharp edge of the casting with the gasket held in place over it and cut the gasket out. |
09-05-2014, 02:35 AM | #7 | |
What #s do you have for Barry ? PM me with numbers and I will compare and see if I can help. Barry told me that he is having a little memory 'situation' ! |
09-05-2014, 12:37 PM | #8 | |
A few years back I purchased some from the Stirum's (not too sure of spelling) I believe they are in the FAST index. Barry was the only one that had new SR diaphragms in recent years. Northwest Speedster's would probably know of a source if there is one currently. Last edited by just plain bill; 09-05-2014 at 12:46 PM. |
09-05-2014, 04:48 PM | #9 |
I still manufacture and sell the Winfield gaskets. Steve
09-05-2014, 06:35 PM | #10 |
09-05-2014, 09:02 PM | #11 |
thanks guys, Barry Bowyer called me back today. I only had one contact number which is his cellphone, which doesn't have a message machine, I got his other phone number thru another site and was able to get in touch.
Also, Steve Sturim thank you for pming me, I will save your contacts for the future. Matt
Matt in Seattle |
09-05-2014, 09:07 PM | #12 |
Can you post Steve and Barrys numbers. I have many Winfields I need parts for.,
09-05-2014, 10:35 PM | #13 |
Steve Sturim 616-538-0441.
09-06-2014, 02:12 AM | #14 |
09-06-2014, 02:16 AM | #15 | |
I ask Steve here if he would post his contact # and he chose to do so. However, I would not feel it right to post Mr. Bowyer # on a public forum such as this. He seems to be very private person ,IMO. |
10-09-2014, 06:51 PM | #16 |
Could anyone confirm if the email address on the Model A Garage site is still the correct one for Barry Bowyer?
www.fordgarage.com/pages/winfieldrebuildkit.htm Thanks. |
12-08-2015, 12:32 AM | #17 | |
12-08-2015, 09:41 AM | #18 |
Waxhead, PM sent.
12-08-2015, 11:36 AM | #19 |
Tom W,
Chief taught me the "FINE ART" of gasket cutting, using a TINY Ball Pein Hammer, TINY scissors, & QUALITY cardboard. By the way, it's handy to buy inexpensive complete gasket sets, MINUS THE HEAD GASKET, to have miscellaneous gaskets on hand. (TIP# 781) I sold one gasket for enough to buy another set, I'm gonna' be RICH! Bill W. Bill W.
02-06-2017, 11:45 AM | #20 |
Sorry to drag this back to the top, but would someone be able to supply me with Barry Bowyer's contact details? I'm still in need of an SR rebuild kit.
02-06-2017, 12:24 PM | #21 |
Did a search and I think the email is now different but the home phone
and address listed in the link to Vince's site are the same. Bob |
02-06-2017, 03:00 PM | #22 |
I can't get a reply on the email. I'll have to call, remembering I'm in the UK so I don't call in the middle of the night.
In fact, now is a good time... |
02-06-2017, 04:06 PM | #23 |
I bought a half dozen gasket sets at Turlock from Barry. The fathers day show I also bought another half dozen rebuild sets, also from Barry. Seems that he goes to the big meets out west. Talked to him about the Big Three in San Diego this month, also a plan to attend and bring some Winfield stuff. He should bring some beautifully restored carbs. Not cheap in that condition. The phone numbers on Vince's sight still correct. Good Luck: Fred A
02-06-2017, 04:43 PM | #24 |
Thanks guys, just called but no reply. I'll try again a little later.
02-07-2017, 02:47 PM | #25 |
02-07-2017, 03:05 PM | #26 |
02-07-2017, 06:33 PM | #27 |
After struggling for a long time to get in contact with Barry, I ended up buying an SR carb kit from Brauns Automotive. It wont be cheap, but if you really need one, contact them and they should have one in stock. Good luck
http://www.braunsautomotive.com/winf...arburetors.asp 24660 Narbonne Ave. Lomita, CA 90717 Office (310) 325-4303 Fax (310) 325-4303 [email protected] Last edited by waxhead; 02-07-2017 at 06:40 PM. |
02-10-2017, 02:26 PM | #28 |
Thanks for tip Waxhead, but Juggler has come up trumps for me.
01-31-2023, 05:26 PM | #29 |
I have 5 new still in their plastic bag Winfield S & SR with pump diaphragm plus instruction ex Barry Bowyer Listed some years ago at $35 a kit , Can freight or deliver too Pate swap meet In April ,2023,
01-31-2023, 06:34 PM | #30 |
The kit for the SR carburetor also includes the diaphragm and spring, valve springs, and phenolic valve discs in addition to the gasket set. Cost is $53.00 plus $7.00 shipping per order. If you want to order a rebuild kit, contact: Barry Bowyer 2509 Valencia Ave Santa Ana, California 92706 (714) 972-1911 home (714) 745-7444 cell
As Carroll Smith wrote; All Failures are Human in Origin. |
02-07-2023, 12:12 AM | #31 |
Another option is a fellow that makes the kits, you must specify either for the a-bb sizes or c to d size. email contact is [email protected] his kit includes base gaskets, float chamber gasket, fuel inlet housing gasket, throttle body to float chamber gasket, accelerator pump diaphragm
02-10-2023, 03:53 PM | #32 |
Barry's home number above has been disconnected. The cell number went to message and the mail box is full so..... John- have you talked to Barry recently??
02-10-2023, 08:10 PM | #33 | |
I may be down that way next week, I'll see if anyone is around. John
