Old 08-30-2013, 12:26 AM   #1
Hitchhiker
Default late 1931 pickup gas tank removal.
My tank has some rust and I was taking it out for cleaning. all the screws and bolts came out easy. It tips up in the front until the fuel tube hits the hole in the firewall. How do I get it out. I cant seem to get it. I started to read about how to get it out and It seems everyone says to try and fix it in the car. If I do go this route I am afraid I already screwed up my welting. Should I just bolt it back in and hope?
Matt in Seattle
Hitchhiker is offline   Reply With Quote
Old 08-30-2013, 01:44 AM   #2
james hitchcock
james hitchcock's Avatar
Default Re: late 1931 pickup gas tank removal.
I'll have to go out tomorrow and look at mine, but isn't there a screw head bolt under each of the windshield post garnish's ? I can't remember. You should be able to tell if you screwed up the welt. That welt is the one thing I hate installing. It's a real booger.
james hitchcock is offline   Reply With Quote
Old 08-30-2013, 03:14 AM   #3
Bill Underwood
Raise up in back first It will pull up at about a 30 degree angle and lift out
It would surprise me if you can reuse welting
It has to be pulled and the trimmed when in place
Good luck
Bill Underwood is offline   Reply With Quote
Old 08-30-2013, 07:27 AM   #4
kelley's restoration
kelley's restoration's Avatar
geez buddy your doing a full on resto of that truck (which i have been following on the hamb)
i hope you took out the tank filler strip out.
and as stated above push the tank up from the inside and pull it out that way. helps to have 2 people
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 08-30-2013, 08:48 AM   #5
chiliman
should poop right out if all bolts and screws are out. you havegone this far take it out and to radiator shop for cleaning and sealing if you are planing to keep your paint on put heavy coat of wax and dont rub off have had two done paint still shines and dont have to worrie about rust flakes have a blessedday
chiliman is offline   Reply With Quote
Old 08-30-2013, 12:52 PM   #6
Hitchhiker
Thanks guys, I dont have the filler strip out. Thats my problem.
Matt in Seattle
Old 09-03-2013, 07:14 PM   #7
Hitchhiker
Does anyone have any advice for putting it back together with new welting? thanks
Matt in Seattle
Old 09-03-2013, 07:40 PM   #8
flatford39
Be patient. It is a real pain in the ass but if your not in a hurry it will turn out nice. You need to pie cut the welting where it is the curved areas and you need a needle nose type pliers to pull the welting from the inside snug. I have done it a number of times but it takes time.
flatford39 is offline   Reply With Quote
Old 09-03-2013, 11:27 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
That +*%#^$# WELTING!!! I have a friend that's a MASTER car builder, fabricator, restorer, etc. None of his Model A's EVER have any welt, ANYWHERE!! After painting & assembley, he caulks the cracks, smooths them very neat, & has his pinstriper paint the caulking to match the other colors! It looks so perfectly done, that NO one ever notices it. He says he still has bad dreams about the last time he TRIED to install that +*^#%$# welting!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-04-2013, 07:30 AM   #10
Mike V. Florida
Mike V. Florida's Avatar
Take an old bed sheet and cut out 1" strips, staple the strips to the welting. This will give you something to pull the welting in place and once in place a quick pull will remove the strips.
Old 09-04-2013, 10:31 AM   #11
Purdy Swoft
Purdy Swoft's Avatar
I think that it will also be necessary to remove the windshield. You will need lots of room to get the 31 tank out from the rear. The welt will be a pita.
Old 09-04-2013, 12:12 PM   #12
Hitchhiker
I do have the originals in good enough shape to use as a pattern.
I also have the windshield out for replacement at this time.
Matt in Seattle
Old 09-04-2013, 12:14 PM   #13
Hitchhiker
Does the welting get glued to anything?
I assume the order of operation would be:
put in the welting.
Put in the tank.
Pull the welting till tight.
bolt tank down.
Matt in Seattle
Old 09-04-2013, 12:55 PM   #14
flatford39
No glue Matt. Don't make it any harder than it is. I like Mike's suggestion about stapling strips of cloth to it. I am going to try that on the next one.
Old 09-04-2013, 03:26 PM   #15
BILL WILLIAMSON
I've seen guys use self adhesive Velcro to hold it in place or to build up the thickness when a crack is too wide to grip the welting well. I had a loose spot in one strip & injected glue with a syringe & taped it down 'til it dried. Bill W.
Old 09-12-2013, 02:47 PM   #16
Hitchhiker
So do i need two different kinds? I ordered the anti squeek welting. But that is only for the firewall and the back? I need another kind for the sides?
Matt in Seattle
Old 09-12-2013, 04:20 PM   #17
Purdy Swoft
yes, Brattons has it on page 57 of their newest catalog Part number 37210 $5.65 for 10 feet.
Old 09-13-2013, 01:29 PM   #18
Hitchhiker
Thanks!
Matt in Seattle
Old 09-21-2013, 04:47 PM   #19
Hitchhiker
The reproduction welting and anti squeak seem a lot different than what I took out. does anyone have pictures of how this goes together?
Matt in Seattle
Thread Tools
Display Modes
