06-01-2013, 04:42 PM | #1 |
Just adjusted brakes....Man does this thing STOP!!!
Like the title says I just adjusted the brakes on my model A. First time I have done it since taking ownership in Feb.
I thought the brakes were a little lacking, but weren't horrible. But now that I have adjusted them, It will throw you threw the windshield. good enough for me!!
Matt in Seattle |
06-01-2013, 06:32 PM | #2 |
Re: Just adjusted brakes....Man does this thing STOP!!!
Hitchiker,
What method did you use for adjustment ? Ford Service manual ? Marc |
06-01-2013, 06:35 PM | #3 | |
I am glad for you. I know it seems like some of us beat this proverbial horse to death but Model-As do require routine maintenance ....and while it is a pain to do, the rewards are generally worth the effort. I bid you many miles of happy trails in your 'new car'. . |
06-01-2013, 09:09 PM | #4 | ||
http://www.fordbarn.com/forum/showth...hlight=barrett It was a lot easier than I thought. Quote:
Matt in Seattle |
06-01-2013, 09:14 PM | #5 |
Man I have adjusted and adjusted and still cant get the stop id like. I hear a lot of you say your car stops great. I just cant get it
06-01-2013, 09:23 PM | #6 |
06-01-2013, 09:29 PM | #7 |
I'm going to pull my drums and check the shoes. They should be good but never know. Only have about 1800 miles on them but hey ill check.
06-01-2013, 09:36 PM | #8 | |
Even if your WHOLE brake system is really up to "SNUFF", brakes will NOT hold well unless your shoes are arced to get 100% contact with the drums. Look at the lining & see how much "SHINES" Bill W.
06-01-2013, 09:41 PM | #9 |
Thanks Bill. I'm going to pull drums and check it all out soon as I can.
