Old 04-10-2021, 12:54 PM   #1
russcc
Default Question about 32-34 spindles
What is the purpose of the heavy bars attached to the kingpins in the '32-34 spindles in the photo. Thank you.
Old 04-10-2021, 12:55 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Question about 32-34 spindles
Old 04-10-2021, 01:31 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
Perhaps it was a way of making shock mounts
Old 04-10-2021, 05:32 PM   #4
DavidG
DavidG's Avatar
The bars are certainly not stock '32-'34 Ford parts.
Old 04-10-2021, 06:24 PM   #5
russcc
Thank you. That's it, they are not stock.
Old 04-10-2021, 08:46 PM   #6
Tim Ayers
Someone also drilled and tap the king pin in order to thread for those bolts
Old 04-10-2021, 09:32 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
And as such, the MYSTERY piece should stay stationary with the king pin, as the king pin is locked-in with the axle, keeping it from rotating when the spindles 'turn'. With that mystery piece remaining stationary, the brake BACKING PLATE(s) will hit it (them) when making a turn. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-11-2021, 05:17 AM   #8
Tim Ayers
Well, just the king pins. Those bars could have been used to hang them from somewhere. If otherwise in good shape and reasonable enough I would pick them up. They will new king pins due to what was done to them.
Come to think about it, I wonder if they were used in some type of trailer set up. Those bars could have been used to lock them down straight.
