Old 04-05-2021, 07:02 PM   #1
Lefthander1930
Lefthander1930's Avatar
Question Charging 6 volt Battery
Any special instructions when going to charge a 6 volt Pos ground Battery while in the car ??
Lefthander1930 is offline   Reply With Quote
Old 04-05-2021, 07:19 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Charging 6 volt Battery
Like anything with the old cars and unknown modifications, it depends on what the car has for a charging system. If the car has an original type generator and cut out relay or an alternator conversion then a person can connect and charge the battery as long as they have a 6-volt charger. If the car has a fun projects regulator on top of the generator then the ground lead should be disconnected from the battery for charging. Just be sure to get a good reconnect before starting the engine. The Fun Projects set up is sentitive to bad connections of either power or ground.
Old 04-05-2021, 08:10 PM   #3
McMimmcs
McMimmcs's Avatar
Here goes, I likely have done it wrong for 25 years but I put the 6 volt negative charger cable on the starter and the 6 volt positive cable on the head bolt. It’s never failed me. Wayne
Old 04-05-2021, 09:14 PM   #4
California Travieso
Send a message via Yahoo to California Travieso
According to the instruction manual for my Schumacher maintainer, that is the correct way to charge a battery in a negative ground car. I didn’t realize that until I read the manual recently.
Of course I’ve been doing it wrong on my Model A for the last 7 years with my a Battery Tender (BT), but it seems to work. The BT is electronic so maybe it can adjust to the polarity. The BT only provides 2 amps of output so it could be that it is not enough current to damage the battery.
David Serrano
California Travieso is offline   Reply With Quote
Old 04-05-2021, 09:23 PM   #5
Synchro909
Synchro909's Avatar
David Serrano
I suspect you have confused your positive and negatives. A 6v Model A is positive earth so you would connect the positive lead to earth, not the negative one. The sparks that will result in doing it that way should alert you to the problem.
Old 04-05-2021, 11:29 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Not to mention the LEDs on a Battery Tender blink RED if connected incorrectly.
Old 04-06-2021, 08:15 AM   #7
Patrick L.
Patrick L.'s Avatar
" The sparks that will result in doing it that way should alert you to the problem. "
LOL !
Old 04-06-2021, 09:18 AM   #8
frank55a
I have been doing it this way since 1963 with both the original generators and 6V alternators using 6V chargers and battery tenders. No problems.
frank55a is offline   Reply With Quote
Old 04-06-2021, 10:36 AM   #9
Patrick L.
Patrick L.'s Avatar
I just use a quick connector with + to grd and - to starter. So I just plug the connector together and walk away.
Old 04-06-2021, 07:25 PM   #10
shew01
shew01's Avatar
Same here.
Old 04-06-2021, 09:55 PM   #11
Hitman
I charge the battery in the car, no matter how the battery is connected. I don’t charge the car.
Positive terminal to the positive battery terminal, negative to negative.
Hitman is offline   Reply With Quote
Old 04-06-2021, 10:24 PM   #12
jerrytocci
Simple and true
jerrytocci is offline   Reply With Quote
Old 04-06-2021, 11:42 PM   #13
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
[QUOTE=rotorwrench If the car has a fun projects regulator on top of the generator then the ground lead should be disconnected from the battery for charging. Just be sure to get a good reconnect before starting the engine. The Fun Projects set up is sentitive to bad connections of either power or ground.[/QUOTE]
Is this info in the paperwork included when you buy a fun projects?
Old 04-07-2021, 12:03 AM   #14
Synchro909
Synchro909's Avatar
That's right, For a positive earth system, negative goes to the battery neg and positive to earth (Head nut)
