Old 03-12-2021, 07:38 PM   #1
19ED30
19ED30's Avatar
Default 32 vs 30-31 radiator different
Does anyone know if a 30-31 & 32 B (4 cyl) radiator core /tank and brackets
( shell mounting down the sides) are the same between the three years, I know the radiator have different bracket for the support rods ,32 narrower & has tab /bracket for hood hinge, 30-31 wider for support rods.
19ED30 is offline   Reply With Quote
Old 03-13-2021, 01:07 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 32 vs 30-31 radiator different
32 top tank is slightly Ve'd in the front.30-31 are flat.
Old 03-13-2021, 01:59 AM   #3
cas3
I have both types here to look at, what are you trying to do?
Old 03-13-2021, 02:03 AM   #4
Charlie Stephens
The filler neck is slightly farther forward on the '32. The brackets to attach the hood hinge are different from the Model A.
Charlie Stephens
Old 03-13-2021, 03:05 AM   #5
19ED30
19ED30's Avatar
I have a New 15 yrs old brass works 31 , was wanting to get my 32 running , I do not have a Shell ( Would Like to find a Nice Original Not show ) & I have a 32 hood /rod support bracket . I was wanting to know if the shell ,grill ( when I find one ) would bolt up to 31 rad maybe relocate cap on tank to line up with shell if required. I know having a 32 is "pricey" and a privilege . I just think havering $3000,00 in a decent radator ,shell & grill is ??!! Just looking to have a nice driver 32 , can not compete with the Cali $$ for parts . I have sold original 32 parts fair prices less then half Febay prices to older gentlemen to help other get the cars on the road ,
Old 03-13-2021, 11:05 AM   #6
TJ
TJ's Avatar
Many many years ago I had a 30 Model A coupe with a '32 commercial shell on it. it fit fine, but I don't know if the if there is a difference between the radiator on a '32 commercial and a passenger car.
Old 03-13-2021, 02:31 PM   #7
Karl Wescott
Karl Wescott's Avatar
The mounting brackets to the frame are slightly lower than 1932, the A radiator will sit about 1/2" too high on the 32 frame. Also as noted the fill neck and hinge mount. Otherwise you should be good to go.
Karl Wescott is offline   Reply With Quote
Old 03-13-2021, 02:42 PM   #8
DavidG
DavidG's Avatar
Tom,
The '32 radiators, four and V8, were the same for both passenger cars and commercial vehicles.
Old 03-13-2021, 07:49 PM   #9
TJ
TJ's Avatar
Dave thanks for that info.
Old 03-13-2021, 08:28 PM   #10
paul2748
paul2748's Avatar
On the street rod my son and I built we had a 32 shell on a model A radiator. It fit ok, don't remember , if anything, we had to do to make it fit. Not much though. But we had the cap on the inside not coming through the shell.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-14-2021, 04:32 AM   #11
19ED30
19ED30's Avatar
Thank you to all that replied to post.
I did have a original pass 32 rad ,shell & insert , trusted a person , parts are now missing.
It any one has a Original passenger shell & Inset send a Private message,
Looking for , on a scale 1-10 like 6-8
Thank you
