Old 03-10-2021, 09:24 AM   #1
russcc
Default Rust protection for springs
Recently cleaned the rear spring assembly for the '40 and am ready to reinstall it. What would be a good way to help prevent surface rust on the spring. Would paint work, or would the flex of the spring affect it ?
Old 03-10-2021, 09:51 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Rust protection for springs
I like fluid film, I spray the stuff on just about everything.
Old 03-10-2021, 09:55 AM   #3
johndee138
johndee138's Avatar
I did my 36 spring with CRC Dry Graphite Lube, essentially a spray paint with graphite in it. It made the leaves very slippery, and then I wrapped the whole kit in PVC underground pipe wrap tape, Wonder #41300 10 mil, x2 in, This keeps out all the grit and flexes to allow the leaves to move freely. No grease to attract and hold grit either.
johndee138 is offline   Reply With Quote
Old 03-10-2021, 10:24 AM   #4
39portlander
39portlander's Avatar
Asbury make a product called Slip plate, basically a dry film graphite lubricant. I have used it on my T's and F150's.
A one quart can is more than enough for several vehicles, good luck and let us know how you make out.
39portlander is offline   Reply With Quote
Old 03-10-2021, 10:28 AM   #5
19Fordy
19Fordy's Avatar
johndee, Thanks for the info. on pipe wrap tape. Didn't know there was such a thing.
Old 03-10-2021, 12:03 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
The spring should have a lubricating fitting in the center bolt, it looks like a grease fitting, but if it was greased it will be internally clogged with grease, should be lubed with spring lube, a mixture of ice machine oil(thin oil), talc,and a dash of ground asbestos, 75%auto trans fluid, 25%talc, talc is one of the ingredients in slip plate. The leaves have groove down center to channel lubricant to the tips-- unless spring was greased, then they will be full of hard grease, once the spring is lubed you will find out how good your shocks are
Old 03-11-2021, 06:09 AM   #7
russcc
What is fluid film. I am not looking to lube the spring, just keep it from rusting after cleaning. Good points about dead grease clogging the spring leaf grooves. I have seen that on other springs.
Old 03-11-2021, 07:26 AM   #8
dan35
I used motorcycle chain lube
dan35 is offline   Reply With Quote
Old 03-11-2021, 08:19 AM   #9
Bored&Stroked
Bored&Stroked's Avatar
I had all the leaves of my 32 springs powder coated. These are new Posies springs, so they have the plastic 'pucks' in them for lubrication. If I was using stock springs, would probably use a spray on graphite lubricant and wrap them.
Old 03-11-2021, 08:36 AM   #10
PeteVS
PeteVS's Avatar
It's a spray protectant / lubricant but it's based on lanolin instead of petroleum. I got a couple of cans from a local parts dealer.
Old 03-11-2021, 12:07 PM   #11
Kube
Kube's Avatar
I powder coat each leaf.
Old 03-11-2021, 12:21 PM   #12
russcc
Fluid Film - Just what I was looking for. Thank you.
Old 03-11-2021, 10:29 PM   #13
1952henry
1952henry's Avatar
Good for spraying in wheel wells of daily driver pickups for winter as well.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
