Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 03-31-2015, 04:39 PM   #1
Bill Goddard
Bill Goddard's Avatar
Default Extra Model A Parts
City: Shrewsbury
State: PA
Price: various
Model A Parts for Sale
* parts unique to '28/'29 Fordor Leatherback body style
*rear seat wood frame 55.00
*front seat wood frame 55.00
*front seat riser 30.00
*front seat side boards 20.00 ea
*rear roof header 100.00
*left rear door opening post 75.00
*front seat to lock pillar fillers 10.00 ea
*brackets - lock pillar to filler 10.00 ea
*front seat floor pan 45.00
*left & right rear lower interior quarter panels - hardboard 20.00 ea
*2 wire clips for drum style taillight support bracket 1.50
6v generator/short taper shaft w/ pulley - overhauled except coils 75.00
rear window shade mounting brackets 3.00 pr
1 window regulator handle with molded edges 6.00
emergency brake toggle lever - original style 12.00
heater valve for firewall 15.00
original style pitman arm w/ restored ball 17.00
license plat mounting bracket for drum taillight 15.00
clutch adjusting toggle - 5/16" thread 4.00
original style battery cable support bracket at flywheel housing 4.00
original windshield support lock knobs 3.00 pr
original floorboard foot rest 2.00
rear brake camshafts - new 7.00 ea
2 LED turn signal bumper lights w/ mounting brackets - amber 12v 15 pr
airmaze carb air filter assembly w/ metal screen 15.00
12v to 6v horn resistor 13.00
2 12v electronic turn signal flashers for LED turn signal system 6.00 ea
main power disconnect switch bracket only - mounts on flywheel housing in engine compartment 4.00
'28-'29 emergency brake handle (mounts in front of transmission) to X-shaft rod 5.00
'30-'31 emergency brake handle (mounts on side of transmission) to X-shaft rod 16.00
'28-'29 firewall cowling webbing kit - original style 6.00
early cast gas shutoff valve handle 6.00
'28-'29 engine water outlet 10.00
Bill Goddard is offline   Reply With Quote
Old 04-21-2015, 10:00 AM   #2
Bill Goddard
Default Re: Extra Model A Parts
btt
