03-26-2013, 05:19 PM | #1 |
Cracked Model A head been brazed...
I recently bought a bunch of original Model A parts at an estate sale. One of the things I bought was a Model A head with the letter B on the top. It has much tighter combustion chamber. Today I put it in my glass bead cabinet to clean it up and much to my dismay I discovered it has been brazed in between cylinder 2 and 3 on the drivers side. It appears that it has been surfaced and used since it was brazed, but I am skeptical of it. Is this head a candidate for the scrap pile??
Unspoken gratitude is helpful to no one. |
03-26-2013, 05:31 PM | #2 |
Re: Cracked Model A head been brazed...
Along the water jacket holes? Is it surfaced within 002"? I have one that I had welded and surfaced there still is a small combustion leak into the water, but no water into the head. I put some non pressurized stop leak in it , and its better. Was going to change it, but never got around to it. It's been two years now. It added 10 miles an hour up the steep hill from the valley to the hill I live on. Chuck
03-26-2013, 05:31 PM | #3 |
Many blocks and heads have been repaired that way. I would try it and see what happens
03-26-2013, 05:35 PM | #4 |
My buddy drives a 1930 town sedan with an original B Head. It is brazed down the top of the water tunnel and between 2 and 3. When I asked him if he was worried about it he said he was for the first 10 years.
Oklahoma City Model A Restorers Group. |
03-26-2013, 05:49 PM | #5 |
Water jacket only right? This one sounds like a "keepah."
Joe K
Shudda kept the horse. |
03-26-2013, 07:30 PM | #6 |
03-26-2013, 09:42 PM | #7 |
I have a "B" Police Head that is cracked in the water jacket (got frozen), but not anywhere in the combustion areas. Only kept it in case someone wanted to try and revive it.
03-27-2013, 08:30 AM | #8 |
Unless you are desperate for a head and can't find another, why would you ever take a chance? I have found used heads to be very cheap !
Al |
03-27-2013, 08:32 AM | #9 |
You have found Police heads cheap? Rod
03-27-2013, 08:40 AM | #10 |
"Unless you are desperate for a head and can't find another, why would you ever take a chance? I have found used heads to be very cheap !
Al " Whats the worst that can happen? Leak a little? If it does, take it back off and bring it to a reputable "engine guy" and he will tell you if it is repairable. Or better yet, bring it to him now. |
03-27-2013, 09:04 AM | #11 |
Thanks for all the advice. The head had already been repaired and yes it is in only the water jacket. It was that way when I got it but I did not see it until I media blasted it. Based on what I have read here, I think the head is usable. Thanks again, I am glad i asked before I tossed it.
Unspoken gratitude is helpful to no one. Last edited by corndog; 03-27-2013 at 09:10 AM. |
03-27-2013, 09:20 AM | #12 |
At some time there won't be and abundance of cheap heads and if the cracked ones are junked where will the hobby be?
03-27-2013, 10:22 AM | #13 |
I recently purchased a Model A and it was good enough to drive through the summer. In the fall I started the restoration and found that the head had a six inch long crack down the center that had never been repaired. It did not leak all summer long, it must have been sealed with rust. But now that new head copper head gaskets are running $25.00, why would you go thru the work of using it? Ed
