Old 06-18-2021, 08:56 PM   #1
amishman
Default 1941 carburetor , where does this part go
I'm new to the flathead Fords, my car was running well when it started to cough a little. Got home a took the top of the carburetor off to look inside for the first time, when a part fell out I can't figure out were it goes. It looks like a small bullet, measures .187 diameter, .406 long with a .154 diameter hole in it.should have been more careful, I've looked at the service manual diagram, but don't see it. HELP
amishman is offline   Reply With Quote
Old 06-18-2021, 09:55 PM   #2
drolston
drolston's Avatar
Default Re: 1941 carburetor , where does this part go
Sounds like the spring loaded "bullet" that gives the choke its detent. If you disconnected the choke linkage that goes from the bottom of the carb to the top, that may pop out. Better find the spring too.
Old 06-19-2021, 02:15 AM   #3
ford38v8
ford38v8's Avatar
A picture is worth a thousand words.
Alan
Old 06-19-2021, 07:11 AM   #4
Terry,OH
Terry,OH's Avatar
It does sound like the spring loaded piston for the choke linkage. The top has a small boss just above the threaded hole for the screw that holds the choke linkage onto the top. The spring for the piston may still be in the hole.
Old 06-19-2021, 08:56 AM   #5
Bob C
Here's a picture from Van Pelt's
There is a bigger picture at link. http://www.vanpeltsales.com/FH_web/F...rd1938to48.jpg
Old 06-19-2021, 10:41 AM   #6
Will D
Will D's Avatar
"9537" in the drawing?
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 06-19-2021, 10:50 AM   #7
scicala
scicala's Avatar
Yes, and the spring behind it is 9587.
Sal
scicala is offline   Reply With Quote
Old 06-19-2021, 03:48 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
Yep, small bullet
Old 06-19-2021, 03:59 PM   #9
Henry Floored
Henry Floored's Avatar
What about #9594?
Henry Floored is offline   Reply With Quote
Old 06-19-2021, 07:09 PM   #10
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by Henry Floored View Post
What about #9594?
Sure, why not. That's what the OP has to figure out.
Old 06-19-2021, 08:12 PM   #11
scicala
scicala's Avatar
What about #9594?
#9594 looks like the accel pump discharge check needle/weight. The carb would need some inside disassembly for that to fall out. The description fits the choke detent bullet. #9594 doesn't have a hole in it.
Sal
Old 06-20-2021, 06:57 AM   #12
amishman
Thanks , ok I understand now.
