Old 03-09-2012, 08:31 AM   #1
C26Pinelake
Cool Is there standards for Model A pinstriping ?
I want to have a 1929 Pickup roadster pin striped and want to know if there is a standard design to be followed ?
Thanks wayne
C26Pinelake is offline   Reply With Quote
Old 03-09-2012, 08:36 AM   #2
HoarseWhisperer
HoarseWhisperer's Avatar
Default Re: Is there standards for Model A pinstriping ?
Covered in MAFCA's Model A Ford Paint & Finish Guide.
I believe there is a revised 3rd edition published.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 03-09-2012, 08:51 AM   #3
C26Pinelake
Thank you. Is this just the colours or the pinstriping placement on the car ?
Thanks wayne
Old 03-09-2012, 09:10 AM   #4
C26Pinelake
I am supposed to have the striping done this weekend and I want to make sure he follows the code. Can I get the right page on line or do I have to put the job off until I can buy the book ?
Thanks wayne
Old 03-09-2012, 12:52 PM   #5
Charles Reese
Charles Reese's Avatar
see attached (28-29 pickup)
please post a photo of your completed work!!
Charles Reese is offline   Reply With Quote
Old 03-09-2012, 01:00 PM   #6
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
yes most definable, check your judging standards on width and such
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 03-09-2012, 06:10 PM   #7
Charles Reese
From J Standards: "Pin striping was applied to all passenger ve­hicles to accent the lines of the car. Pin striping was applied by two workers, one for each side of the car as it traveled down the assembly line. Conse­quently, variations in line width or pattern some­times existed on the same car. Special lacquer paint was used since the paint had to be dry within 10 minutes. Ford specified a particular pinstripe pattern for each body. The width of pin striping was specified as 1 /8" wide with a few exceptions. In actual practice, all pin striping was actually closer to 3/32' wide, re­gardless of the specified line width."
Old 03-11-2012, 12:16 PM   #8
frank55a
Charles,
Which revision of the J Standards did you quote or where did it say what you quoted? I could not find that in the 2011 revision.
frank55a is offline   Reply With Quote
Old 03-11-2012, 02:30 PM   #9
Charles Reese
sorry, its from the paint manual .. i believe the 2nd edition.
however, JS 14-1&2 has additional info (2011 revision)
Old 09-21-2022, 05:54 PM   #10
DavidWeeks
I have a 31 cabriolet 68 bravo, and I am looking for information on the Pinstriping I know the color but I'm not sure of that pattern and if there's Pinstriping on the inside of the car is there anybody out there now?
DavidWeeks is offline   Reply With Quote
