09-24-2022, 07:23 PM | #1 |
Waterpump no fit,
Struck a curly one today , Friend imported a late 31 coupe ex Texas,came with high back seats & part of air con unit in the trunk, no problem removed them in preparation to getting it complied in NZ, We fitted Mitchell trans, overdrive, Engine is a diamond B with the short water pump , Fitted a 6.1 snyder head & went to put the new A water pump on , However it touches the radiator, Checked all measurements, cowl to fire wall etc, engine mounts etc only to find the gap from the A head to radiator is an 1 " too small ,compared too other 30- 31 ones here, Bit of head scratching, few choice words, re checked length of pump etc , Turns out this has a thicker core by at least an 1" no way will stock A pump & fan fit, So its either a new radiator, or fit the old B head & 34 short water pump back on , Guess previous owner fitted a truck radiator as it gets hot in Texas ,But hotter in AZ ??
Any better solutions out there ??? or struck this problem before, ??? Least its spring time in NZ, Thanks |
09-24-2022, 07:36 PM | #2 |
Re: Waterpump no fit,
Putting a B motor in an A takes a bit of work due to the oil pan and flywheel housing differences. I'd have to ask how that all was handled? Certain ways of mounting might affect engine location.
09-24-2022, 08:18 PM | #3 |
The thicker core is probably for an AA truck.
09-24-2022, 10:20 PM | #4 |
I agree with Ray. I have a 30-31 truck radiator and it is about 1/2 inch thicker than a car radiator. Truck shell is thicker as well. I can take measurements if you like.
09-24-2022, 11:40 PM | #5 |
Derek: I ran across this problem with a water pump from one of our US Vendors. The shaft is too long. NOT Sure who made it, looked ok but shaft was too long....
09-25-2022, 03:48 AM | #6 |
09-25-2022, 09:57 AM | #7 |
The AA radiator is thicker towards the front so should affect the fan clearance.
09-25-2022, 01:53 PM | #8 | |
Charlie Stephens |
