09-20-2022, 11:27 AM | #1 |
31 roadster rumble seat foot area
My roadster needs the floor pans in the foot area of the rumble seat, nothing came with the car so i call snyders and we can't figure out what i need. There is a pan for a coupe that is 36 1/2 by 18 1/2 that will drop right in the sub rail pocket but it's not for a roadster, the angle floor pan that belongs there i can not figure how the heck it will fit in the sub rails.
angle floor pan a151 a (for rumble foot area) rumble floor panel A351B for 31 coupe Anyone have an answer or better a pic ? always thanks for the help kurt or maybe both pans need to go there. |
09-20-2022, 11:37 AM | #2 |
Re: 31 roadster rumble seat foot area
Hope this helps. The angled floor pan for the seat. The foot area at the top. The curved section at the bottom to allow the rumble lid to open
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 08-07-2023 at 05:59 PM. |
09-20-2022, 12:06 PM | #3 |
Thanks for the pic, it's the area where the feet are is my question, if you could take a pic from the front back , the pan that the feet rest on is the problem, is that pan aprox 36 1/2 by 18 1/2 inches and sits in the sub rails ?
thanks for the pic kurt |
09-20-2022, 02:48 PM | #4 |
Hello,sorry I don’t have and pictures of the 30-31 roadster floor, I bought some from Snyders, there is a floor panel directly under the seat riser that is a compartment for the side curtains and fits underneath the angle panel. They fit to the side sub rails and body sub frame. My car is in storage, if I get a chance will get some pictures of it . Also originally all the panels are riveted in so you have to drill them out .
09-20-2022, 04:50 PM | #5 |
Check out pages 7 and 8 at the link. https://www.diyauto.com/manufacturer...by-flop/page/1
09-20-2022, 05:22 PM | #6 |
Bob from Northport Northport, Michigan |
09-20-2022, 05:25 PM | #7 |
Here is another photo
09-20-2022, 06:18 PM | #8 |
thank you Bob C, that is just what i needed to see and Bob from northport you were also a big help.
thanks kurt |
09-20-2022, 11:12 PM | #9 |
Kurt,
You need Snyders # A 151 A which is the angled floor pan and you also need A 123 B which is the seat riser that goes under the back rest cushion for the front seat. The sloped part of the floor attaches to the angled side supports of the seat riser. The flat part of the floor fits between sub rails. Attached is a picture of the floor area. Look closely and you can see where the sloped part of the rear floor fits onto the sides of the seat riser. I hope this helps. Chris W. |
09-20-2022, 11:29 PM | #10 |
Kurt,
This is another picture of the underside of the body showing the A 127 A that fits under the front seat bottom cushion seat riser A 121 B. The curtain pan extends part way back under the sloped part of the Angle Floor Pan. I hope this helps, Chris W. |
09-21-2022, 10:21 AM | #11 |
CWPASADENA, GREAT PICS thanks help a lot.
kurt |
