Old 09-17-2022, 02:26 PM   #1
The Geezer
The Geezer's Avatar
Default I give up!
I have tried to rebuild my Marvel carb to no avail. Gushes out fuel no matter what I do. Put in a new Under the dash shut off valve from Snyder, replaced all the jets and gaskets from Dave Renner, and tried 3 times to set the fuel bowl level.
So, I am looking to buy a totally rebuilt and set up Marvel carb for my 1931 Model A Sport Coupe. Any help pointing me in the right direction would be most appreciated.
Regards to all, The Geezer
“Finally driving a car older than me!”
The Geezer is offline   Reply With Quote
Old 09-17-2022, 02:32 PM   #2
ndnchf
ndnchf's Avatar
Default Re: I give up!
Call Gary Johnston. He can rebuild yours or probably sell you one.
903.490.3725
Curious - is your float valve not sealing? I just put a new float and valve from Renners in mine yesterday. It works great.
ndnchf is offline   Reply With Quote
Old 09-17-2022, 02:39 PM   #3
The Geezer
The Geezer's Avatar
Thanks for the info! Yes, I put in a new float valve with the Vito’s rubber tip. I was careful to inspect it for burrs or brass chips. I rebuilt it a few weeks ago and had no problems…until it started to drip out the back intake. Then I suspected that the shut off valve was leaking and replaced it with a “gauranteed not to leak” USA valve from Snyder. All was well until I hooked everything up to check the fuel level in the bowl and turned on the valve…result was gushing fuel. Took everything apart 3 times adding washers to the float valve…with the same result.
Old 09-17-2022, 02:45 PM   #4
ndnchf
ndnchf's Avatar
Thats odd. Give Gary a call, nice guy to talk with. I'm sure he can fix you up one way or another.
Old 09-17-2022, 05:05 PM   #5
The Geezer
The Geezer's Avatar
Thanks much, will call on Monday!
Old 09-18-2022, 11:35 AM   #6
katy
katy's Avatar
Did you try tap tap tap on the fuel bowl when the fuel was running out?
Old 09-18-2022, 12:13 PM   #7
ronn
Berts has rebuilds on the shelf.............
Old 09-18-2022, 03:34 PM   #8
The Geezer
The Geezer's Avatar
Yes tapped on the carb to try and stop the fuel flow to no avail. When I had the carb apart (3 times) the main fuel flow valve and float was working fine when I blew into the inlet and moved the float up to stop. I will be calling Gary Johnston tomorrow to see what he suggests.
Thanks to all who replied!
Old 09-18-2022, 04:15 PM   #9
J Franklin
J Franklin's Avatar
The test I learned was suck on the inlet on an inverted carb. creating a vacuum, use your toung to hold, and see if it holds.
Old 09-19-2022, 12:09 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
Geezer, where is the fuel "gushing" out?
Unlike a Zenith, a Marvel Schebler has a seal on the GAV and will leak gas from there. Ensure the GAV seal is installed.
Also, I make my own gaskets from Buta-N/Cork. The Marvels tend to warp if the screws are tightened too much and the paper gaskets are too hard to seal. Only tighten the screws enough to collapse the lock washers.
I found the above works for me but I'm sure I will get some negitive feedback...
Old 09-20-2022, 10:05 AM   #11
katy
katy's Avatar
Originally Posted by Y-Blockhead View Post
I found the above works for me but I'm sure I will get some negitive feedback... [/COLOR][/SIZE][/FONT]
Not from me!
Old 09-20-2022, 11:57 AM   #12
nkaminar
nkaminar's Avatar
Sounds like a warranty issue. I would take it back to the Ford dealer.
Old 09-20-2022, 01:09 PM   #13
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Gary Johnson is you man. He will sell you a rebuilt Marvel for $200 or he can repair your current Marvel....
Dick M is offline   Reply With Quote
Old 09-20-2022, 03:08 PM   #14
nkaminar
nkaminar's Avatar
Marble Misery Oil will fix it.
Old 09-20-2022, 03:42 PM   #15
Y-Blockhead
Originally Posted by nkaminar View Post
Marvel Misery Oil will fix it.
It should, the same dude made them both...
Old 09-20-2022, 06:56 PM   #16
The Geezer
The Geezer's Avatar
Sent my unMarvel to Gary and he is rebuilding it. I suspect the GAV was the culprit but
could not get it to seal properly even with new parts from Dave Renner.
