03-30-2023, 09:06 AM | #1 |
California prices
I had my 6V-12V starter completed by a local generator starter shop. I took it apart and drill and tapped the holes for the strap to keep it together. The shop cleaned up the old armature, installed a new bearing in the old end plate, reassembled and tested. $80
I also had my flywheel resurfaced. 2 older, rated high on YELP, don't do that but one recommended this place. I thought they did the pressure plate as well but no. The resurface of the flywheel was $55. The days of finding that old mechanic that does this stuff in his sleep are gone, especially in the big city in CA. I thought the prices were fair and reasonable. Now to find a pressure plate re-furbisher. I hate just buying new, but also don't like to spend extra $$. |
03-30-2023, 10:38 AM | #2 |
Re: California prices
You can try Fort Wayne clutch, they should be able to do it.
03-30-2023, 11:00 AM | #3 |
If you can contact the Early Ford Store in San Dimas,CA. Whoever does his does a great job.
03-30-2023, 11:54 AM | #4 |
Scott52. What is your location in California?
Henry Ford designed the flathead without the aid of a computer. |
03-30-2023, 02:14 PM | #5 |
Clutch Masters, on Valley, in Rialto, was excellent ten years ago. I don't know current situation. They were able to do all this, including surface and balance, while you wait. great products, great service.
03-30-2023, 02:56 PM | #6 |
03-30-2023, 03:01 PM | #7 |
03-31-2023, 09:45 AM | #8 |
I am in San Jose. I know I can buy new but there's just something in me about tossing something that could be good.
