View Poll Results: What do you burn in your Model A ?
Straight Gasoline 36 36.36%
Ethanol Blend from Gas Station 32 32.32%
A mixture of Ethanol and Straight Gasoline 4 4.04%
Straight Gas with additives 17 17.17%
Ethanol Blend with additives 16 16.16%
Multiple Choice Poll. Voters: 99. You may not vote on this poll
Old 06-12-2021, 08:27 PM   #21
WTSHNN
WTSHNN's Avatar
Default Re: Ok, i'll poke the bear..Ethanol or Straight Gasoline ?
Cheapest at the pump.
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 06-12-2021, 09:17 PM   #22
TerryH
TerryH's Avatar
Here in California we have no choice, so all Model A’s here have to run on ethanol. I also add MMO routinely. By the way, I am no fan of ethanol, but honestly I have had zero problems using it for 15 years now, other than I have heard you get a bit less mileage and performance.
TerryH is offline   Reply With Quote
Old 06-12-2021, 11:16 PM   #23
ETAModel
I've been using straight gas and MMO, May blend in some E-15, see how it works out.
looks like its about even, 50/50 on Ethanol Vs Gasoline
ETAModel is offline   Reply With Quote
Old 06-13-2021, 01:44 PM   #24
eagle
eagle's Avatar
If you're driving regularly use whatever mix you want. In the fall as you drive less and then park it for winter, I ONLY use non-ethanol. If you ever wonder what it looks like over time, put some in a vented glass jar. It ends up with some nasty crud in the bottom after sitting a month.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 06-13-2021, 02:02 PM   #25
ETAModel
My buddy has an ATV/motorcycle shop. Does sales, repairs/service.
He told me when he opened he'd get in a few carbs every year that needed cleaning due to sitting up. Then E gas showed up at the pump and the number of repairs on carbs went thru the ROOF. He did nearly 500 in one year.
Most of his clients are friends and family, he'd much more like to work on things other than the carb. He told me he started telling folks to run straight gas in their ATV's etc, and the # of repairs has fallen dramatically, so he can do other pursuits.
He said he only bought the shop cause he raced moto-x and wanted to be able to work on his stuff when he wanted..he makes his $$ in other places.
So it seems if you drive it regular than whatever is fine. If you do the once a month drive you should run Real Gas.
Its interesting to see the poll results.
Thanks for the replies.
Old 06-13-2021, 04:27 PM   #26
GPierce
GPierce's Avatar
Ethanol is a solvent. Ethanol dissolves the varnish that builds up in that e fuel systemms over the years. That varnish residue ends up in you carburetor. That’s why they can’t add ethanol at the refinery. It would dissolve all the junk in the pipe line. We have Valero refinery here. There are hundreds of tank cars in their yard with ethanol in them. They add the ethanol simultaneously with pumping gas into the tankers.
Once that is cleaned out you shouldn’t have problems except for storage and water absorption in damp climates. Automobiles today have sealed fuel system so that is not a problem. Model A’s breathe in air to replace the fuel you burned and that brings water vapor in to be absorbed by the ethanol. When the ethanol gets saturated corrosion starts.
Ethanol adulterated gas about 10% less BTU’s per gallon compared to gasoline.
GPierce is offline   Reply With Quote
Old 06-14-2021, 10:23 AM   #27
mgambuzza
mgambuzza's Avatar
Non ethanol and MMO - Syracuse, NY.
mgambuzza is offline   Reply With Quote
Old 06-14-2021, 11:06 PM   #28
ETAModel
Originally Posted by hazelhoff View Post
In WW2 Model A’s ran on generators fed with wood ! Indeed, they will run on anything !
Can you elaborate on this just a little.. i'm not grasping what you're saying.
