Old 08-10-2018, 03:38 PM   #1
Corn Fed
Corn Fed's Avatar
Default 32-33 BB Rims
Does anyone know if Model AA big truck rims will bolt up to '32-33 BB big truck hubs? Is there a difference or are they maybe the same? A couple of the ones on my '32 are shot and I need something to be able to at least yard drive it with. I figure finding some off an AA will be easier than finding BB's.
Corn Fed is offline   Reply With Quote
Old 08-10-2018, 04:36 PM   #2
Bob C
Default Re: 32-33 BB Rims
1930-34 are the same bolt pattern, they changed in late 1934 when they went
to the full floating axles. You need to be sure the lock rings match the wheels as
there are two different ones.
Bob
Old 08-11-2018, 05:59 AM   #3
truckdog62563
truckdog62563's Avatar
This will add some info on the subject. All the letter codes (DT, L, RH, etc) are the rim design designations. As said above, keeping the rim/ring sets together as matched sets is critical to safe assembly and operation. Stu
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
