10-26-2019, 06:32 AM | #21 | |
Re: Mercury crank
10-26-2019, 07:06 AM | #22 |
Re: Mercury crank
I would venture to guess that it is just a safety precaution.
One less thing that could go wrong,,,you know. We tend to run more pressure in our engines now,,,,so a plug could possibly blow out. Also,,,,you need to remove them to clean the passages . So might be a good time to upgrade. Of course,,,like you said,,a plug worked for millions of engines before. However,,,I will probably use a fair amount more oil pressure,,,so,,,I know what direction I am leaning towards. Thanks for the reply Gary. Tommy |
10-26-2019, 08:52 AM | #23 | |
Re: Mercury crank
Why "use a fair amount more oil pressure"? Is it really needed? It will heat the oil more by churning it through the bypass valve as well as require more horsepower to drive the oil pump. Bearings are lubricated by the hydrodynamic wedge action of a rotating shaft. The oil pump merely supplies the needed oil to the bearing. |
10-26-2019, 09:12 AM | #24 |
Re: Mercury crank
Well my reasoning is I have heard many stories of only 10 pounds of pressure before.
I am sure that some engines will live with that,,,,,but,,,the stresses placed on a high performance engine are greater. Yes,,,the hydrodynamic wedge is there,,,,but,,the added load is detrimental to the oil film provided on the journal. The load against the journal doesn’t just increase,,,but it could increase by the square,,or even the cube. Also,,,some oil passages are not as friendly to good flow as others are. Some cranks are machined where the oil passages actually act as a pump themselves. The angle of the passage,,,the angle the oil hole comes out on the rod at top stroke. This can act as a pumping action,,by centrifugal force,,,,it literally helps sling the oil through the crank. Also,,,,during some high rpm,,,high load forces,,,the oil can stop in its tracks,,,,,for just a millisecond,,,. There are a lot of forces involved,,,,that is why they went from just dippers and oil slingers. The power levels got to the point that it couldn’t lubricate anymore and the pressurized oil systems were created Then later,,,,the full filtration filter systems evolved as well. I don’t plan on too much pressure,,,I like to have al least about 30 or so at hot idle,,,then around 60 at RPM. Just my observations. Tommy |
10-26-2019, 09:21 AM | #25 |
Re: Mercury crank
I've got over 60,000 miles on my engine and the oil pressure never drops below 30 lbs. 60 at startup. This is with a stock 8BA pump. The 10 lb stories are old history.
10-26-2019, 09:34 AM | #26 |
Re: Mercury crank
Good to hear that. Like I said,,,I don’t intend to use too much pressure,,,just a fair amount. By the way,,,what pump do you use,,,stock type Ford,,,Melling? Tommy |
10-26-2019, 10:23 AM | #27 |
Re: Mercury crank
I don't think you can beat a stock ford pump if it's in good condition. Certainly don't use a Speedway Motors pump. I put one in a brand new engine and it only made 15 lbs at hot idle. I replaced it with a known good Ford (tested by none other than "flatjack9"), and my hot idle is now 35 lbs.
10-26-2019, 10:55 AM | #28 |
Re: Mercury crank
Awesome Denny.
That is information that I can use. Since this is a crank thread. What about the Merc cranks,,,,do they hold up well in stock form,,,or should they be modified for oil flow? This flathead stuff fascinates me,,,I’m like a kid in a candy store. Tommy |
10-26-2019, 02:11 PM | #29 |
Re: Mercury crank
There is a severe impact --- due to the heavier Merc crank, I have found that I have had to counterbalance that with a heavier foot on the gas pedal . . . the net result is that my mileage tends to suffer . . .
10-26-2019, 06:44 PM | #30 |
Re: Mercury crank
Flatjack9, 10/30 oil??
10-26-2019, 07:02 PM | #31 |
Re: Mercury crank
Yes
