06-13-2015, 08:26 AM | #1 |
6volt Tachometer
06-13-2015, 03:04 PM | #2 |
Re: 6volt Tachometer
I have the same problem. I put an Autometer tach on my column, since i could not find a nice, period looking 6 volt tach. I think I'm going to try one of those 6 to 12 volt converters that are used for radios, buy yikes! they are $60 on ebay. I'm trying to find something a little cheaper, but I may have to raise my standards....
Frank |
06-14-2015, 12:41 AM | #3 |
Keep searching on eBay and you can find vintage SUN tachs and the correct black box to operate it.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-29-2015, 03:40 PM | #4 |
Sun tachometer control boxes need to be fully rebuilt prior to usage. They contained a battery type that is no longer made and often have serious corrosion on the points mechanism.
www.morrisgauge.com |
06-29-2015, 03:58 PM | #5 |
Back in the 60's I was driving a 1940 tudor as my only car, and was working at the local ford dealership. I liked the look of the tach on the falcon sprint and the brand new mustang, so I bought one and installed it on the 40 ford. It worked fine on 6 volts, positive ground. I still have the tach. I should connect it on the model A and see how that works.
06-29-2015, 04:01 PM | #6 |
Bob |
06-29-2015, 10:21 PM | #7 |
A 2 & 1/16th diameter 6 volt positive ground rotational sweep tachometer is a tall order. I know of no such brand.
06-30-2015, 09:40 AM | #8 |
I had this place make a small run of tachometers for a specialty application. The price wasn't bad and their website says they'll make up one custom gauge.
http://www.newvintageusa.com/nvu.html
kris |
