07-21-2023, 10:43 AM | #1 |
Ford Locksmith
Can someone give me a phone contact for John Mc Clure the locksmith? Thanks 40 larry
07-21-2023, 11:19 AM | #2 |
Re: Ford Locksmith
Making the simple complicated for over 30 years. |
07-21-2023, 12:22 PM | #3 |
Re: Ford Locksmith
A related question - how do know what a door key code is? I need keys for my '35 doors.
07-21-2023, 12:55 PM | #4 |
Re: Ford Locksmith
Cutting keys without the code. Locksmiths can do a key impression when they do not have the key code. Buy the correct key blanks and take them and the cylinder to a locksmith and we will do what this guy below does.
https://www.youtube.com/watch?v=1uZjyWVcglI |
07-21-2023, 12:58 PM | #5 |
Re: Ford Locksmith
Are the doors keyed different than the ignition key? On my 1937 the door key and the ignition key are the same. To find out what the code is for the door lock, you can remove the door lock cylinder and the code should be printed on the side. The difficulty in removing the cylinder can be the small slotted set screw that retains it can be rusted in place. Proceed carefully and use a good penetrating oil. The set screw is located through a small hole on the edge of the door. You do not want to break off the head of the slot.
07-21-2023, 01:14 PM | #6 | |
Re: Ford Locksmith
07-21-2023, 01:21 PM | #7 |
Re: Ford Locksmith
07-21-2023, 01:41 PM | #8 |
Re: Ford Locksmith
07-21-2023, 02:30 PM | #9 |
Re: Ford Locksmith
Screws like that are difficult to drill out ,I did one and wished I didn’t.
07-22-2023, 09:04 AM | #10 | |
Re: Ford Locksmith
You are also correct in that the set screw in '37 is slotted, NOT a recessed hex type.
07-22-2023, 09:37 AM | #11 |
Re: Ford Locksmith
12-05-2023, 01:04 PM | #12 |
Re: Ford Locksmith
Does anyone have a key code list for crown keys that fit Model Ford door handles
