Old 06-15-2014, 08:36 PM   #1
LSJUNIPER
Default Distributor
Was putting the distributor on my 39 flathead tonight, it's the original one for the motor. The cam is new. I double checked the number on the order form for the cam, it is supposed to be for the 39..Here's the problem the key on the distributor does not engage with the keyway in the cam....Do I have to replace the cam, hope not expensive mistake...is there an adaptor to make this work as is????
LSJUNIPER is offline   Reply With Quote
Old 06-15-2014, 08:59 PM   #2
Andy
Default Re: Distributor
There is an adapter button that is used with a later style cam and an early helmet distributer. It is a disk with a key on one side and a groove 90* on the other side.
Andy is offline   Reply With Quote
Old 06-15-2014, 09:13 PM   #3
Phil Gillespie
Phil Gillespie's Avatar
Just a thought. Check to see the off set is line up correct. if 180 degree out cannot be aligned.
Phil
NZ
Phil Gillespie is offline   Reply With Quote
Old 06-15-2014, 09:25 PM   #4
Ol' Ron
Ol' Ron's Avatar
Yes, why doesn't it fit??
Old 06-15-2014, 09:29 PM   #5
LSJUNIPER
Yup, the offset is correct..it's about 3/8" short...
Old 06-15-2014, 09:29 PM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Yes, you need that adapter. Speedway has it 15 bucks . Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 06-15-2014, 09:35 PM   #7
LSJUNIPER
Thanks for the tip guys...I am a flathead noob...wouldn't of made any progress without this forum!!!!!
Old 06-15-2014, 09:50 PM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Be careful which adaptor button you buy and use. Some are poorly made and will allow the distributor to fit 180° out of phase and turn the distributor shaft without breaking the distributor casting.
John
Old 06-15-2014, 10:06 PM   #9
LSJUNIPER
Ok JM.....Will be careful...
Thread Tools
Display Modes
