Old 11-09-2017, 12:07 PM   #1
burner31
burner31's Avatar
Default Model A lubrication chart
Anyone have a usable/readable (for these old eyes) of the Model A lubrication chart?
Can't seem to find one online that I can zoom in on and read clearly.
Also having problem visualizing location: (from pg14 of model A instruction book)
*Approximately every 2000 miles, lubricate the clutch release
bearing. This is done by removing the hand hole cover and
turning the bearing until the lubricator fitting is at the top.
Lubricate the bearing by means of the compressor grease gun.
What's the hand hold cover and where's that bearing?
Keith
Shawnee OK
'31 SW 160-B
Old 11-09-2017, 12:19 PM   #2
Jw
Default Re: Model A lubrication chart
Going to Okemah this weekend, may stop by and help you identify the lubricating locations, thanks, Joe in Denver
Jw is offline   Reply With Quote
Old 11-09-2017, 12:49 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I bought the large lube chart at a national meet, but I think all the parts houses sell it also. It's nice to frame and hang on the garage wall.
Old 11-09-2017, 12:55 PM   #4
Tom Endy
Tom Endy's Avatar
I believe this statement is referring to the early cars that used the multi-disk clutch. The clutch release bearing (throw-out bearing) had the grease fitting in the bearing and you had to rotate the bearing in order to get at the grease fitting. The hand hole cover must be a reference to the little removable plate on the top of the bell housing.
Tom Endy
Old 11-09-2017, 12:57 PM   #5
burner31
burner31's Avatar
That's a very kind offer Joe, I'm going to Missouri this Saturday, to look at some parts, and have dinner engagement this Sunday.
I'll PM you and maybe we can still do this on both our schedules.
Keith
Keith
Shawnee OK
'31 SW 160-B
Old 11-09-2017, 02:55 PM   #6
lindy williams
According to the V8 service bulletins Ford changed to a sealed throwout bearing starting in 1935, so if your bearing has been changed since 1935 it is probably a sealed bearing anyway.
lindy williams is offline   Reply With Quote
Old 11-09-2017, 03:29 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
And remember, if you have your sealed T.O. Brg out, they can be re-packed with a wheel bearing packer. I even re-pack a NEW one. Sometimes the Factory Grease is like VASOLINE!
Bill Slick
"THE ASSISTANT GURU OF STUFF"
Old 11-09-2017, 06:16 PM   #8
Tom Wesenberg
I often pop the seal off one side of a sealed bearing, so I can check the amount of grease. Quite often there's barely enough to smear on a fingertip. In other words many rebuilt parts have just enough grease to make it to the end of the warranty.
Old 11-09-2017, 06:53 PM   #9
1931 flamingo
1931 flamingo's Avatar
A Fresnel (sp) lens is your friend, or a magnifying glass.
Paul in CT
Old 11-09-2017, 09:55 PM   #10
Gary WA
Gary WA's Avatar
Like this? Vendors sell, Take to print shop have enlarged.
www.whidbeymodelaclub.com
Old 11-10-2017, 01:43 AM   #11
Randy in ca
Randy in ca's Avatar
Here's a link to one from Vince Falter's website. Click on link then click on image to enlarge.
http://www.fordgarage.com/pages/modelalubrication.htm
Randy in ca is offline   Reply With Quote
