10-28-2022, 08:54 AM | #1 |
Metal Data Plate
Hello all, I have a question in regards to the Metal Patent plate that gets attached to the firewall.
How do I attach to the firewall, I know the fuel tank is right there and I don't want to drill into the tank. Thanks! |
10-28-2022, 09:29 AM | #2 |
Re: Metal Data Plate
28 & 29 cars have the upper firewall in front of the actual front wall of the tank. There is enough room between to set the rivets for a patent plate. The rivets generally come with a new plate and are not difficult to set. They are drive type rivets. Just back them up with a piece of bar stock and drive them in with a correct size setting tool. They have spiral gripping flutes that hold them solid.
Take care removing the old ones. You don't want the holes to get oversized if possible. Last edited by rotorwrench; 10-28-2022 at 09:40 AM. |
10-28-2022, 10:14 AM | #3 |
Canton - there should be holes in the firewall for the rivets for the data plate. No drilling should be required.
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
10-28-2022, 10:52 AM | #4 |
will I be able to use a simple hammer to drive the rivet in, or do I need a special tool (yet something else to order)
10-28-2022, 10:58 AM | #5 |
Drive them in with a hammer.
10-28-2022, 04:11 PM | #6 |
JayJay
