04-03-2023, 08:00 AM | #1 |
Made my own.
I thought I would share my tool I made for my front spring restoration project. I didn't have a KR Wilson tool and since the spring was already out of the vehicle, I decided I would make my own and use my 20 ton press for the job. I cut the threads off the bolt and used just the body of the bolt. I then turned 1-3/4" of the shank down to .003 smaller than the OD of the bushing body. Then I machined 3/16" step OR rabbit (if you will) to fit inside the outer body of the bushing where the rubber starts. I then bored a 1/2 hole in the center 3/8" deep to clear the square shank of the stud....THEN drilled and tapped the center for 3/8-24 thread AND now it threaded onto the stud and snugs up against the outer body of the bushing ALL Lined up. It took 2 minutes to press them out!!!! Thanks to guys like "Mart" (and others) here on the barn that are inspirations and teachers to guys like me!!! I am also, SO very thankful to, not only have the facility BUT to have my wife who is very supportive of me having and acquiring the tools I have to do ALL that I need to do!!!!
04-03-2023, 08:07 AM | #2 |
Re: Made my own.
Wow!! Nice work and bet it's a very satisfying feeling to have done that!!
04-03-2023, 08:22 AM | #3 |
Re: Made my own.
Robert,
Now you have to channel that creativity into making up what you will need for the other half of the job, the installation of a new studded bushing. |
04-03-2023, 08:35 AM | #4 | |
Re: Made my own.
GLAD to see it looks as IF you arrived home safely?? I was worried you might hit some pretty in-climate weather?? Time for a much deserved "Rest"!! |
04-03-2023, 09:23 AM | #5 |
Re: Made my own.
Well done. Home-built tools are so satisfying!
Terry
04-03-2023, 09:41 AM | #6 |
Re: Made my own.
04-03-2023, 09:52 AM | #7 |
Re: Made my own.
Great job, Robert.
04-03-2023, 10:32 AM | #8 |
Re: Made my own.
Yup, every growing boy should have a lathe. Nice job there. When you have a press, its especially nice to make the correct size driver on the spot for safe easy pressing.
04-03-2023, 11:47 AM | #9 | |
Re: Made my own.
I have an Idea working right now, fortunately in my line of work I have a wide variety of customers that have all kinds of scrap so I will perloin something from one of them. I am thinking on machining a socket affair that slides on over the eye of the spring and is the about .003 bigger in diameter as the bushing eye and has a slot where it slide over the flat of the spring and act as a guide to put the bushing in and press it with my press. I am thinking I might also "ever so slightly" turn a chamfered edge on the bushing to help self alignment in going in the eye.....AND IF need be I have two really really good and sharp machinist that will lend a helping hand (or machine IF need be). I will post what I end up with!!! ALSO, after my first one, I need to make a few small "adjustments/improvements" SO IF you like I will turn you one and send it along IF you like??? THANK YOU for all the kind compliments guys & to 34Fordy for looking out for me!!! |
04-03-2023, 01:07 PM | #10 |
Re: Made my own.
Great tool!
04-06-2023, 04:03 PM | #11 |
Re: Made my own.
Very professional Robert. I won’t describe the goofy backyard ways I’ve gotten these little villlains out .
04-06-2023, 04:17 PM | #12 |
Re: Made my own.
I remember taking a vise to the rear axle to replace bushes. Easier than pulling the axle.
04-06-2023, 05:16 PM | #13 |
Re: Made my own.
Good job! I have not tried it yet, but I have a couple of these beefy OTC U-joint presses like the one pictured. I need to make an adapter to slip over that male end to press those original bushings in without damaging the outer thin shell. I have a 40-ton press too just incase I want to damage the bushing even faster than the clamp. I've been looking for a KRW tool for a couple of years without any luck. This project is coming up on my '34 pickup.
I pressed in a lot of modern truck spring bushings at work, and they were easy because the outer metal bushing was so thick, you couldn't damage them, plus they didn't have a stud that you need to position at the correct angle. I haven't done one of the Early Ford's yet. It's fun figuring out how to do this stuff. Last edited by Flathead Fever; 04-06-2023 at 05:29 PM. |
04-06-2023, 08:09 PM | #14 |
Re: Made my own.
Rockfla, Sounds like you are getting a good education on running your lathe. It's always fun to learn new skills and from the sounds of it, this appears to be some complex tooling. I will be watching and learning as you do your next chapter.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
04-07-2023, 03:19 AM | #15 |
Re: Made my own.
Lathes are great, It's excellent that you are using it to make tools. I use my lathe most days and it's a real boon to any tinkerer's shop. I show it quite often in my videos.
04-07-2023, 06:37 AM | #16 |
Re: Made my own.
I salute you sir; that's something my dad would have done. I sadly lack the skill set. Well done!
04-08-2023, 12:43 AM | #17 |
Re: Made my own.
I catch myself looking at lathes on craigslist. Seattle 'WAS' a real blue collar town with many residents in highly skilled jobs like the shipyards and Boeing. Now their stuff, obviously well cared for is getting sold by the next generation. Most of the ones I could justify buying are either really small or tremendously large. Not sure I know the right size for a tinkerer. But that sounds like a thread in itself. Maybe next week I'll start one.
04-08-2023, 09:48 AM | #18 |
Re: Made my own.
Ryan has another forum that would be better suited for this; it's called "The Garage Journal". I'll bet there are tons of information about this on it.
04-08-2023, 05:09 PM | #19 | |
Re: Made my own.
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
04-08-2023, 07:24 PM | #20 |
Re: Made my own.
I have a cheap ($700) imported lathe with a 7" swing and a 14" reach. I find it fully adequate for the things I need to do in my advanced years. I use it extensively building my condensers. I've had it about 7 years now, and have had to replace a couple of parts, but they were available and for a decent price. One of the things that I checked out carefully was the availability of spare parts. I bought it from an outfit called "Little Machine Shop" (who specializes in smaller end machine tools), and they really have this stuff covered. They also offer a mini-mill that I am considering acquiring.
Almost as important as the price was the size and the ability to run on regular power. I got a real good deal on a used floor model drill press a few years ago and it turned out fine, with the exception of needing three-phase power. Since we did not have it at our location, our choice was to change the motor, or use a phase converter. While the latter is cheaper, the motor produces only 2/3 of it's rated power (we went with it anyway). Too small? there is currently a thread on the H.A.M.B about brake lathes, where a couple of guys described now to use a regular lathe to turn drums. Since a Ford drum is 12", and my lathe has a 7"swing, it should work for me as well. |
