Old 12-08-2023, 06:58 AM   #1
danliveshere
danliveshere's Avatar
Default Procedure for filling a rebuilt columbia axle
Hi everyone. Can anyone please explain the procedure for filling a Columbia axle that has been rebuilt and is completely empty. I can’t seem to find the instructions, it was a real safe spot I put them in! Thanks Dan.
danliveshere is offline   Reply With Quote
Old 12-08-2023, 08:00 AM   #2
glennpm
glennpm's Avatar
Default Re: Procedure for filling a rebuilt columbia axle
"LUBRICATION INSTRUCTIONS – IMPORTANT
With rear wheels off of floor fill rear axle through filler hole in Two-Speed Axle housing with 4½ Pints of standard Ford rear axle lubricant. (DO NOT USE CUP GREASE ) Start motor, shift transmission into high, and Two-Speed Axle control valve in high, depress clutch pedal to floor board, which completes shift in rear axle. Allow clutch pedal to return and run five minutes in this position. This is for the purpose of circulating oil through the entire Two-Speed Axle Unit. Next remove jack and with wheels on floor, BE SURE to refill axle to new oil level plug."
I just changed my fluid. For the refill it took 4 pints however I am not able to run it as above to see if it needs to be topped off.
Glenn
Old 12-08-2023, 09:28 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
The internal planetary gears get lubed only by the oil slung off the rotating assembly ,guided by ridges, baffles into the planet gearcase this is the reason for running it no load when first installed and rechecking, once it has been run and filled it won’t drain during a oil change unless it has been modified somehow
Kurt in NJ is online now   Reply With Quote
Old 12-08-2023, 09:46 AM   #4
glennpm
glennpm's Avatar
Originally Posted by Kurt in NJ View Post
The internal planetary gears get lubed only by the oil slung off the rotating assembly ,guided through this is the reason for running it no load when first installed and rechecking, once it has been run and filled it won’t drain during a oil change unless it has been modified somehow
Thanks for that Kurt
Glenn
Old 12-08-2023, 05:32 PM   #5
danliveshere
So guys is all the oil only added into the Columbia side and no need to add anything into the ford side of the axle?
Old 12-08-2023, 07:10 PM   #6
Ken/Alabama
Ken/Alabama's Avatar
Correct, don’t use the filler plug in the banjo , use the filler plug in the Columbia unit. The only exception to this is for the Lincoln with the Hypoid rear. A true Zephyr A-6 housing has no filler plug like the Ford unit. But the two will interchange. If a Zephyr A-6 is to be used on a Ford then a filler hole needs to be drilled but a Ford on a Zephyr just don’t use the plug. Here’s a couple I have. Note the difference.
Old 12-08-2023, 08:13 PM   #7
glennpm
glennpm's Avatar
That’s interesting
Old 12-08-2023, 10:14 PM   #8
petehoovie
petehoovie's Avatar
Old 12-09-2023, 02:12 AM   #9
danliveshere
Thanks everyone. Job done.
