11-30-2022, 08:29 PM | #1 |
rear brake drum puller
what is the best rear brake drum puller??. I had one that i lent out but never got it back. I only used it once, it was in a nice wooden box cant remember the brand name, would like to get another one, thanks stan white.
11-30-2022, 08:47 PM | #2 |
Re: rear brake drum puller
KR Wilson ! Hands down
11-30-2022, 08:54 PM | #3 |
Vintage precision, hands down!!! THE best V8 Ford specific tool I have ever bought!! NO offense to Ken/alabama above. The K R Wilson is good too!!! IMO. The vintage precision is better!! *****NOTE****** “IMO”!!!
11-30-2022, 09:05 PM | #4 |
I have not used the KR Wilson tool, but also highly recommend the Vintage Precision tool. Works every time
11-30-2022, 09:33 PM | #5 |
Stan , this is the one that came in the wood box. Sadly, it's no longer being made. However, the pullers mentioned above work just fine.
11-30-2022, 09:52 PM | #6 |
Alan |
11-30-2022, 09:53 PM | #7 |
I ordered the Vintage Precision puller. I was truly amazed at the high quality of this tool. When was the last time you unpackaged a new purchase and it far exceded your expectations? Worked as good as it looked. They really should make a king pin removal tool based on the old KR Wilson type.
11-30-2022, 10:01 PM | #8 | |
11-30-2022, 10:03 PM | #9 |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 11-30-2022 at 10:08 PM. |
11-30-2022, 11:17 PM | #10 |
Here's the one you're talking about, and the one that I chose. They show-up on eBay with some regularity.
Coop |
11-30-2022, 11:55 PM | #11 |
Except when the key catches the drum, wrong edge up. Happened to a RG # 85 member. Newc
12-01-2022, 07:35 AM | #12 |
I’ll have to look into that. Didn’t know that existed. Something new every day!
12-01-2022, 10:01 AM | #13 |
petehoovie: Thanks for enlarging the puller photo.
12-01-2022, 10:33 AM | #14 |
I have 3 Winfield tool works KR. Wilson pullers all barely used. I would sell one. Do not have wooobox. That was an option.
12-01-2022, 11:15 AM | #15 |
I would be interested in one , No i do not have the box . If you are interested in selling one give me a call. Thanks Stan 775 364 4367 Northern Nevada
12-02-2022, 10:03 AM | #16 |
x2!
12-02-2022, 12:40 PM | #17 |
I always say if a hub comes off with a puller other than the ones mentioned, it wasn't tight enough!
12-02-2022, 12:52 PM | #18 |
One that I built, works great!
12-02-2022, 01:17 PM | #19 |
TO Marts point
AND can of "worms" now open......ANYONE with the vintage precision puller notice in the directions 125ft Lbs of torque is the MAX suggested for pulling a hub......AND Isn't 200ft Lbs the recommended torque for the installation of the drum???? Quite the difference Kube & 38FordV8 Tomato Tomotto Right?? Only difference is Vintage Precision is basicaly "On Demand". K R Wilson most likely NOT so much!!! Last edited by rockfla; 12-02-2022 at 01:24 PM. |
12-02-2022, 03:08 PM | #20 |
I didn't notice the VP instructions stated 125 ft lbs. I'm normally fearing for my mortal life when winding it up! I'm glad there is a nut on there or the hub might take the wall out!
Nice job Wat-0! |
