04-06-2011, 02:21 PM | #1 |
Maximum Bore + Stroke
On the Model A engine how much, if any, can the stroke be increased? Mainly wondering about space in the crankcase to swing a bigger crank. Would the maximun bore be about 1/8th inch oversize? I am familiar with the V8's but not so much the A. Thanks.
04-06-2011, 02:35 PM | #2 |
Re: Maximum Bore + Stroke
My last engine was bored .125 over which is the max bore. If I use it again it will have to be sleeved.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
04-06-2011, 02:39 PM | #3 |
Maximum bore probably varies from block to block, depending on water jacket proximity, any core shifting, etc.
Have heard 0.060" overbore is common, 0.080 is "possible", and 0.100" is probably the absolute max IF you have enough meat in the water-jackets. That's still a bit less than 1/8"... Don't know about stroking... you might achieve 4-3/8" stroke by grinding the rod journals off-center... Watcha thinking about doing with this engine ? |
04-06-2011, 03:00 PM | #4 |
My inserted bearing engine with just under 50,000 miles is bored .125" over. Zero problems during those miles. The next step would be sleeves if ever re-built. I do not have any problems with it running hot...I added a thermostat to get the temp up.
I've built a few others at this same bore with no problems. Dave in MN www.durableperformance.net |
04-06-2011, 03:05 PM | #5 |
Flathead,
I have an old race engine, 1950-1960, it's a B, with off set ground rods to work with A rods. The block is .125 over to .135 over, V/8 60 main bearings and a reworked V/8 oil pump. Dudley |
04-06-2011, 03:07 PM | #6 |
04-06-2011, 05:57 PM | #7 | |
My best running A engine was bored to 4.030. I have been working on a destroked A engine we will see if it works out. |
04-06-2011, 06:21 PM | #8 |
I just finished boring a engine to put sleeves in. I always use the thick wall sleeves that are .125 thou thick each side. This means I have to bore the block to 4.125 to have the sleeve a .002 thou interference fit. I do this all the time and have never hit water. I would say the block could be bored at least to 4.250 with no problems.
04-06-2011, 07:21 PM | #9 |
Thanks for all the responses, I was thinking about a torquey touring motor as opposed to higher RPM. Putting dimples in the pan is not a problem, but how much clearance is there between the rods and the camshaft for a longer stroke?
04-06-2011, 08:22 PM | #10 |
I used "Skokie" A rods and had no clearance problems. The engine does have a lot of torque and goes pretty fast 1/4 of a mile at a time.
04-06-2011, 11:48 PM | #11 |
What gasket are you guys using for .125" bore? I'm having a hard time finding a B head gasket for that bore size, and the A head gasket I used before is no longer available.
Chuck |
04-07-2011, 10:46 AM | #12 |
Just plain Bill is right, he's "been there, done that". Back in the day many racers bored them to 4 1/16" with no problems but I recommend 4" to be the maximum. A 'B' crank can be offset ground to give 3/8" stroke, clearance between the rods and the crank, and between the rods and the pan get real close, so be careful. Guys used to use Pontiac rods, they had to be modified to clear the cam and often the cam was ground to clear them too. The old cam grinders knew right where to grind them.
04-07-2011, 10:57 AM | #13 |
Just thinking out loud here... stock stroke ( 4-1/4") is already fairly long and torquey; if you're looking for a touring engine with a little extra "grunt", how about a touring cam and perhaps 5.5:1 "police head"... ?
Sounds like "stroking" a Model A might be a complicated and delicate art... |
04-07-2011, 12:10 PM | #14 |
You're right, a touring cam and 5.5 or 6 head is what I will probably do. However there is that "no substitute for cubic inches" rule that is still valid, especially with a Flathead. Just trying to do my homework on this.
04-07-2011, 01:33 PM | #15 |
if you look at the hamb and a guy with then screen name crazydaddyo. you will see that he has had one or two cranks break after doing this offset grinding.
i think you are really just making things more complicated for yourself. just put in a mitchell or volvo overdrive and call it a day. then its just bolt ons without sacraficing reliability just my .02 tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information [email protected] |
04-07-2011, 02:31 PM | #16 | |
04-07-2011, 10:11 PM | #17 |
I agree that a damper would be a good idea, and of course the crank has to be ground right.
04-07-2011, 11:29 PM | #18 | |
An overdrive won't help ya if your engine doesn't have the oats to turn it. Remember the old adages, "There is no substitute for cubic inches". "Speed cost money! How fast do you want to go?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
04-07-2011, 11:34 PM | #19 |
Dave,
How is your engine with inserts? Is it a much stronger bottom end? Issues with bearing failure eliminated? Thanks, Steve |
04-08-2011, 12:20 AM | #20 | |
Yes, I have broken two cranks. They both were B cranks ground to A mains and rods. Rod journal offset ground .187" for a total stroke of 3/8". Fillet radii were too small, but even .125" - .187" radii are hard to get with this big of an offset grind. Bore was 4". As Bill has said, If you are only expecting your engine to go short distances fast, stroking it is advantages. But if your building a touring engine, then changing the stroke is a waste of money. Head, Cam, And carb are your best "bang" for the buck. I prefer the T-5 trans. but I will be banned from this sight if I talk any more about "non-stock" alterations. . |
04-08-2011, 11:30 AM | #21 |
4" bore with a 1/4" longer stroke + 225 inches, with a 4 3/8" stroke it = 239 inches. The difference in torque is amazing!
04-08-2011, 03:31 PM | #22 | |
04-08-2011, 05:06 PM | #23 |
I was looking at the new block/crank made by Burtz. They offset the location of the rod caps so the rod wouldn't hit the cam. Very close tolerances. How close do the rods come to the cam in a stock block with a stroker crank?
http://www.modelaengine.com/12.html
04-08-2011, 09:15 PM | #24 |
Yes, I think a bigger stroke would help the low RPM power, just where you can use it on the road. No need to rev it up and strain anything. I guess this is pretty much what Bill already said.
04-09-2011, 10:16 AM | #25 |
04-09-2011, 03:02 PM | #26 | |
I was referring to the 3/8" stroke in my statment. Sorry I should have made that clearer. You are right the increased stroke will give you better torque. And as long as you don't go much more then 3/16" you will still have a motor that will hold up to the rigors of touring. In my mind the cost of stroking an engine ($1,500 - $2,000) is a little much to add to your touring engine build cost . |
04-09-2011, 07:11 PM | #27 |
If your going to spend that kind of money, a swap to a pinto or chev II with a 5 speed is what i woud do (or a flathead). I know , it won't be 'original" then.
Paul in CT |
04-09-2011, 11:35 PM | #28 |
Don't want to open up that can of worms. My choice is to keep the original engine. I like the honest simplicity of the Model A. Just looking at some concealable "tweaks".
04-10-2011, 12:13 AM | #29 |
I agree with Vince and George that you already have plenty of stroke, and adding to it won't increase the cubic inches by much, even if it does give you some more torque AT LOWER RPM's.
I'd use a H/C head and counterweighted crank, and if you want more speed use a 3.54 or 3.27 rear end. |
