Old 08-30-2019, 04:05 PM   #1
Bob Johnson
Bob Johnson's Avatar
Default Water pump ?
How can I tell if a rebuilt water pump has grease-less bearings/bushings in the front and/or rear.
Bob
Bob Johnson is offline   Reply With Quote
Old 08-30-2019, 04:08 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Water pump ?
See if it will take a few shots of grease.
Old 08-30-2019, 09:01 PM   #3
31 Vicky
The front bearing with the fan off you can see the seal on the ball bearing. The rear is more difficult, the pump needs to be pulled, you can see the Rupert machined bearing and seal holder.
A's Always Dave
31 Vicky is offline   Reply With Quote
Old 08-30-2019, 11:56 PM   #4
J Franklin
J Franklin's Avatar
Check it the easy way!
Old 09-01-2019, 12:15 PM   #5
Bob Johnson
But would pumping grease into a grease-less water pump harm it?
Old 09-01-2019, 12:33 PM   #6
J Franklin
J Franklin's Avatar
It won't take any if it is greaseless. just use a hand pump grease gun.
Old 09-02-2019, 12:54 PM   #7
rotorwrench
rotorwrench's Avatar
If the passage is blocked, it won't accept grease. I don't know it the passage is blocked or not. I'd have to see one apart to be certain. I still use the OEM style.
Old 09-02-2019, 01:25 PM   #8
J Franklin
J Franklin's Avatar
If a passage that should be open is blocked it was a poor rebuild.
