04-22-2019, 01:46 PM | #1 |
Stewart Warner speedo. question
Installed a new set of S/W gauges in my Av8 build but need info. on speedometer cable installation. Did a Google search and drew blanks.
Top loader trans from a 36 standard Wings gauges. Any thought or input? Prefer not to use electronic speedometer. Appreciate any help |
04-22-2019, 01:52 PM | #2 |
Re: Stewart Warner speedo. question
What rear-end are you using and tranny??
Paul in CT |
04-22-2019, 02:59 PM | #3 |
This isn't helping you, but I got tired of fighting the speedometer problems on early Fords so on cars converted to 12 volt and using aftermarket electric gauges I have went to GPS sending units. I install then so only the sharpest eye will spot the sender. Not very old timey but they are super accurate and work great.
04-22-2019, 07:51 PM | #4 |
I'm back. There is thread over on The HAMB discussing your problem and a listing for a company that will make you a custom cable to fit your situation. Maybe you are the same guy on the HAMB?
04-22-2019, 08:07 PM | #5 | |
Edit, found it. https://www.jalopyjournal.com/forum/...n-av8.1147490/ Last edited by Tim Ayers; 04-22-2019 at 08:18 PM. |
04-22-2019, 09:35 PM | #6 |
