Old 03-23-2019, 04:11 PM   #1
Bob Johnson
Bob Johnson's Avatar
Default Headlight Sockets
Who sells the headlight socket shown in the picture below. Note that the Headlight bulb socket has a black finish. Also note that the contacts for the bulb are flat and brass without and solder "bumps".
Bob
Bob Johnson is offline   Reply With Quote
Old 03-23-2019, 06:36 PM   #2
ericr
ericr's Avatar
Default Re: Headlight Sockets
are these rebuilt originals?
ericr is offline   Reply With Quote
Old 03-23-2019, 06:53 PM   #3
Bob Johnson
No they are reproductions.
Old 03-23-2019, 09:01 PM   #4
54vicky
54vicky's Avatar
no pictures showing if it is my eyes then I will return my buck rogers eyeglasses
54vicky is offline   Reply With Quote
Old 03-24-2019, 10:37 AM   #5
Badpuppy
The black finish would have to be conductive - it's in the bulb grounding path. I can't guess its purpose. Maybe a dark metal plate?
The flat contacts mean crimped connection instead of solder. A soldered connection can be repaired more easily.
Badpuppy is offline   Reply With Quote
Old 03-24-2019, 10:43 AM   #6
30 Closed Cab PU
Do not know who makes them, but is curious the socket pin contacts appear to be correctly sized, not like most repops where the contacts are too large diameter and are prone to shorting.
30 Closed Cab PU is offline   Reply With Quote
Old 03-24-2019, 11:08 AM   #7
Bob C
Maybe A&L??
Old 03-24-2019, 05:44 PM   #8
rotorwrench
rotorwrench's Avatar
Black finish on steel is likely a phosphate treatment. It would still be conductive but more resistant to corrosion than some treatments. Zinc or cadmium plate are generally more common but also more expensive.
