04-09-2017, 02:12 PM | #1 |
Play in Steering Gear
https://www.youtube.com/watch?v=aISGxwIRfCc
Noticed this play while replacing my wheels. I am going to check the frame to steering box bolts now, but are there any other adjustments / attachments I should be looking at?
Our 1931 Station Wagon: Originally restored in 1962, redone in the early 1980's, brought back to life in 1997 and refreshed in 2016/2017. Check out the progress at a31woody.com |
04-09-2017, 02:30 PM | #2 |
Re: Play in Steering Gear
The video is so short it's hard to tell but it looks like end play.
Bob |
04-09-2017, 03:39 PM | #3 |
Agree the video was a blip....to me it looked like side / bushing play....
04-09-2017, 03:46 PM | #4 |
To me it looked like fore play...video too short.
04-09-2017, 04:53 PM | #5 |
https://www.youtube.com/watch?v=Uy5KOhvN8To
Ok, here is a longer clip. Pretty sure the mounting bolts aren't snugged down as much as they should.
04-09-2017, 04:59 PM | #6 |
04-09-2017, 06:14 PM | #7 |
Two words... finger tight. I've got everything snugged back up with new cotter keys. Easy fix, but still frustrating.
04-09-2017, 06:51 PM | #8 |
04-09-2017, 06:52 PM | #9 |
Probably me of the past 🤡 Sent from my iPhone using Tapatalk
04-09-2017, 07:07 PM | #10 |
04-09-2017, 07:29 PM | #11 |
I had much less movement than the video and the bolts were tight. I removed the bolts and they had considerable wear. Gas tank column support allowed enough flex to put a pretty good torque on the long arm from the steering wheel to the steering box. I also replaced the column support with the later model mount to the dash and everything is now solid as a rock.
John |
04-10-2017, 11:10 AM | #12 |
04-10-2017, 12:04 PM | #13 |
Wowza - wondered why Henry used cotters and castles there... Now we know! Standard lock washer would have gone missing ages ago.
1929 Model AA - Need long splash aprons! |
04-10-2017, 01:11 PM | #14 |
End play on the sector shaft. Too loose bolts , 3/8 bolts instead of 7/16 ? For the steering to work properly, everything must be tight. go around to the engine side of the box and loosen the lock nut, gently snug the bolt up. (GENTLY!) and lock it up.
Terry |
04-10-2017, 01:57 PM | #15 |
