Old 12-06-2018, 04:47 PM   #1
rhphotord
rhphotord's Avatar
Default Cowl Band installation help needed
I must be an idiot asking this question but what's the trick you use to install a 30 cowl band. Body is on the frame and just trimming it out but I can't get the lower mounting bolt on the drivers side to align with the mounting hole. It appears clear and should line up from what I see. Stock cowl band came with car and it was on it when I got the car and retaining clips are in place.
Looks like a simple installation but really tight quarters to work. I'm not about to give up but I had to walk away from the car after two hours of frustration!
Help appreciated!
rhphotord is offline   Reply With Quote
Old 12-06-2018, 04:53 PM   #2
Don Turley
Don Turley's Avatar
Default Re: Cowl Band installation help needed
If you have already attached the opposite side, go back in loosen the nut almost all the way off, down to the last couple of threads. Then try again to start the second one. Once you have them both started, then tighten each side a bit at a time until you are satisfied with the results.
Don Turley is offline   Reply With Quote
Old 12-06-2018, 05:52 PM   #3
Init1
Init1's Avatar
Keep at it. Its a bugger but it will go back on. Make sure only a couple threads are used on the first side.
Try doing the other side first if you can't get it to reach.
Init1 is offline   Reply With Quote
Old 12-06-2018, 10:14 PM   #4
burner31
burner31's Avatar
Agree with post 2 and 3.
If your hand is too big get someone with a smaller hand in there to help out.
Keith
Shawnee OK
'31 SW 160-B
Old 12-07-2018, 08:46 AM   #5
desotoguy
Four (4) hands pushing it down at various points will help get it aligned and the second nut started. As other posters have said, only start the first side.
desotoguy is offline   Reply With Quote
Old 12-07-2018, 12:53 PM   #6
rhphotord
rhphotord's Avatar
Did start one side and it was painful to even get eight turns on the nut. Maybe I back that off and give it another try. Used to skinned knuckles working on this old car just thought there was a "magic" trick out there!
Old 12-08-2018, 10:16 AM   #7
rhphotord
rhphotord's Avatar
After about two hours of struggle finally got the drivers side band threaded stud in place. Had to remove the passenger side completely and re bend (several times) the drivers side orientation of the stud. Today I tackle the passenger side. Tightening the nuts should be fun. If I ever do this again the band gets installed before the body gets mounted on the frame. Working blind in a confined place isn't fun. Lots of words I can't repeat in the presence of young ears! Thanks for the insight!
Old 12-08-2018, 10:35 PM   #8
rhphotord
rhphotord's Avatar
Done!!!
