03-22-2016, 07:59 AM | #1 |
Another Seat Belt Thread
Hi All!
I am about to install seat belts in my Cab so I'm looking for advice and/or suggestions on that from any one who has done an installation on a 68A or similar body style. I searched the forum but did not find anything that specific. I did read about Juliano's retractables with the anchor plates they offer. So far that seems the best option depending on the complexity of the installation. i.e. would I need to do any modifications? How or where are the backing plates attached? Many thanks for any and all suggestions on Juliano's (or maybe an alternate source) as well as installation tips! |
03-22-2016, 08:39 AM | #2 |
Re: Another Seat Belt Thread
Google "put 3 point retractable seat belts in roadster" to see a ford barn post on the subject. PM me if I can help.
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
03-22-2016, 12:39 PM | #3 |
I put lap belts in my 30 roadster and it was simple but maybe the cabriolet is different. I mounted a 1/4"x 4" steel plate full length under the rumble seat riser then drilled and mounted the anchor bolts and threaded the belts under the backrest cushion and above the base cushion. I think Bruce Adams of L.I. NY has belts installed on his 30 cabriolet.
03-22-2016, 12:52 PM | #4 |
Not sure about your installation but Andover Restraints has some nice belts at a good price and they're DOT approved. I put a set in my OT '31.
03-22-2016, 01:32 PM | #5 | |
03-23-2016, 01:23 PM | #6 |
I felt this was a reasonably strong set of anchors, all things considered. I did the work when I replaced all body wood and floor sheet metal. It would be more difficult to do this way if the body was not in some state of disassembly. |
