08-09-2010, 10:57 AM | #21 |
Re: 78-7006 is this a special transmission case?
Remember that the cast number on the case is NOT the part number as sold over the counter. The PN over the counter was 7005 for the regular V8 case and the other numbers as posted for other versions...
On the V8 one, the reason for the number change from 7006 is that you could not buy a truly bare 78-7006...it came only with the clutch shaft bushings installed, so in Fordspeak it was an ASSEMBLY needing a new number, not a single part. |
08-10-2010, 11:24 AM | #22 | |
Also, it is an another flathead myth that Ford gear sets (main drive and large cluster gear) have to add up to "44". It is the meshing diameters and gear shapes that have to match. |
08-10-2010, 03:10 PM | #23 | |
worth more than the rest of it no doubt... Thanks for the info...
Early V8 Garage Pasadena Roadster Club |
08-10-2010, 09:43 PM | #24 |
That sure looks like a model B trans. Same as a V8 but different starter location. The man said it has a strange gearset. Probably is from a 4 cylinder '41 or '42. The model B and the model 40 with B engine had the same gears as the V8.
'32 4 cylinder is a model B '33 and '34 with 4 cylinder were model 40 with B engine. Often referred to as the "C" model. |
08-11-2010, 09:54 AM | #25 | |
Actually from a 40-41? Commercial with 4cyl tractor motor... And it IS strange...
08-11-2010, 10:59 PM | #26 |
I cleaned the case and tumbled with "steel shot" and it does in fact have a 9C <-> 1057XX number on the case. When I first looked at it quickly I read it as 90XXX. Last edited by Benson; 08-12-2010 at 07:03 AM. |
08-11-2010, 11:34 PM | #27 | |
