Old 03-27-2017, 02:29 PM   #1
CB919ER
CB919ER's Avatar
Default help in chattanooga, tn
I'm reaching out for some help. I have a 29 model a that I need to pull the gas tank so I can clean, treat, and seal. The car has been sitting with some gas in the tank since the mid-90s. I've heard of using white vinegar to clean the metal, but I still want to coat the inside. Is anyone in the Chattanooga area that can give me hand to remove the tank? I currently live in Knoxville and if you like you can ride down with me.
Thanks in advance guys!
CB919ER is offline   Reply With Quote
Old 03-27-2017, 11:31 PM   #2
H. L. Chauvin
Default Re: help in chattanooga, tn
Nine (9) hours and no response?
Usually after one Forum response, appears the Forum ice is broken.
Maybe call MAFCA for a TN Model A Club.
Hope someone can assist ..... always met lots of good people from TN.
H. L. Chauvin is offline   Reply With Quote
Old 03-28-2017, 08:29 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Chattanooga is kinda slim now on Model-A folks. Bill Underwood told me he is beyond covered up and has throttled back. The late David Moore would have been the perfect person. There's the Smokey Mtn Model-A club in Knox, and there are a couple of guys down in Loudon area, but they are probably like everyone else and extremely busy with 'life'. I wonder if you would be better off to get the car back to Knoxville and then see if someone like Vic Varady could put the word out.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-28-2017, 08:59 AM   #4
Gunmetal blue2
Gunmetal blue2's Avatar
I live in Columbia, TN but I can't drive any more. Wish I could help.
Gunmetal blue2 is offline   Reply With Quote
Old 03-28-2017, 11:35 AM   #5
jmalex1929
Are you wanting someone in the Chattanooga area to remove the tank clean, seal and replace it
jmalex1929 is offline   Reply With Quote
Old 03-28-2017, 05:02 PM   #6
jdupay
jdupay's Avatar
For what it is worth, I used a product like this several years back. My tank was all rusted inside and used this product - needed 3 fills and rinses not just one - but the inside of my tank is like new. I did not seal it afterwards, I just keep it full of gas and it fine. http://www.orisonmarketing.com/evapo-rust.html. I did this whole process without removing the tank. Filled through top, drained through gas on/off valve inside the cab. (tubing, buckets and a few rags :-) )
Joe
Minneapolis, MN
1929 Std Coupe
jdupay is offline   Reply With Quote
Old 03-29-2017, 07:35 AM   #7
tinkirk
tinkirk's Avatar
I've got a 29 now that the tank was filled up before parking it in 1965! tried Acetone and that kind of worked but the fumes are not nice, started putting a couple gals of E-85 gas (if you want to call it that) shook the car as hard as i could, stuck an air hose in the tank and bubbled it and, drained it out the bottom had to take the valve out the bottom and install a hose to it so i could blow air backward to open the hose up before draining it,did that once a day for about a week, pretty much took care of the problem still have a little more cleaning to do but at least i was able to put gas in and get the motor back running again
Good Luck on how ever you decide to take care of the problem
Terry
tinkirk is offline   Reply With Quote
Old 03-29-2017, 08:26 AM   #8
CB919ER
CB919ER's Avatar
if I can get the tank off then I can clear and treat the tank myself, I've done several motorcycle tanks before, I just don't know how to get the tank off the car.
thanks for the tip, I'll look into it.
