06-05-2023, 12:38 PM | #1 |
Cloth covered coaxial / shielded cable for open car antenna
I struck out with RI Wire; would greatly appreciate other source suggestions.
Probably need 12-16’ to allow for transverse connection of running board antennae and, knowing me, at least one mistake along the way. Thank you all.
No job’s done ‘til it’s all done |
06-05-2023, 02:13 PM | #2 |
Re: Cloth covered coaxial / shielded cable for open car antenna
I bought the wire for spare tire antenna
Tyree Harris i think |
06-05-2023, 02:56 PM | #3 |
Thank you, will check
06-06-2023, 04:01 PM | #4 |
RG59 TV coax is not a perfect match but will work in a pinch.
06-06-2023, 05:01 PM | #5 |
Thank you Pete; when using the RG59 (or any coax), what is the circuiting for an antenna ?
06-06-2023, 05:07 PM | #6 |
06-07-2023, 05:14 PM | #7 |
Thank you
