02-03-2020, 07:12 PM | #1 |
steering box
I saw some where that people added a grease fitting on the bottom of the steering box to lube it.
My dumb question is can I put the grease in where the plug is on top of the box ?? My old age and bad back does not feel like making the grease fitting on the bottom of the box |
02-03-2020, 07:45 PM | #2 |
Re: steering box
Don't use grease to lube the steering box. Since it is not a liquid it won't flow between the gears thus drying them out. It will just be displaced by the gears. Use the proper gear oil to lube the gears.
02-03-2020, 08:34 PM | #3 |
Re: steering box
That fitting is to lube the sector shaft bushings.
02-04-2020, 12:25 PM | #4 | ||
Re: steering box
02-04-2020, 04:39 PM | #5 |
Re: steering box
It’s installed between the two bushings and the lube goes between them. Some cars have this. I’m talking two tooth
02-04-2020, 05:21 PM | #6 |
Re: steering box
02-04-2020, 06:08 PM | #7 |
Re: steering box
This applies to the 7-tooth steering: green is oil 600/680. Red is high pressure grease.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
02-04-2020, 10:29 PM | #8 |
Re: steering box
No, the sector bushing are greased from the bottom. The oil from the box should not go past the first bushing. Keeping the sector shaft greased also aids in keeping oil from seeping past these bushings.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
02-06-2020, 12:25 PM | #9 |
Re: steering box
I put grease in the Gemmer gear box to seal the sector bushings, then I put a few table spoonfuls of SAE 140 gear oil in the box. This technique stops the inherent oil leakage, and I have been doing it since 1962. It works!
Bob Bidonde |
