Old 11-27-2020, 10:49 PM   #1
Kevin Bovee
Kevin Bovee's Avatar
Default YOM License Plate Frame
Getting ready to register Ruby the truck and was double checking fit on my ‘39 NM plate. Of course when I ordered a new frame I forgot that these old plates are not the same size as current plates.
In conversations with a CNC fabricator, but wondering if there is a more affordable route. The measurements are approximately 13 3/8 x 6 1/8.
Thanks.
File Type: jpeg AD1058E0-F82C-4B5D-AA79-CA3FBA33848A.jpeg (114.9 KB, 22 views)
Kevin Bovee is offline   Reply With Quote
Old 11-27-2020, 11:18 PM   #2
Steve in Denver
Steve in Denver's Avatar
Default Re: YOM License Plate Frame
If you find a source, put me down for two. This would seem like a great idea for the EFV8 foundation to add to their inventory. 12 1/2 x 5 3/8
Steve in Denver is offline   Reply With Quote
Old 11-28-2020, 09:55 AM   #3
19Fordy
19Fordy's Avatar
Gee, the plate looks fine without a frame.
Old 11-28-2020, 10:22 AM   #4
Kevin Bovee
Thanks, I agree it looks good without a frame. I want one so I can put a plastic cover over it for a little more protection.
Old 11-28-2020, 06:45 PM   #5
42guy
42guy's Avatar
A couple of years ago, there was an outfit that made an ajustible (sp) frame. I saw it on the internet, but don't their name.
42guy is offline   Reply With Quote
Old 11-28-2020, 06:52 PM   #6
billybronco1
I went through the same thing, could not find a plate frame 121/2 x 61/2 with holes to line up so I used this plastic trim, works for me.
billybronco1 is offline   Reply With Quote
Old 11-28-2020, 07:07 PM   #7
19Fordy
19Fordy's Avatar
You could make your own out of Lexan. We used to make them in our metal shop class using a plastic strip heater. All you have to do is heat the plastic and make a single lap joint on top and bottom. Then slide it over the license plate. Then put a dab of silicone caulk at end of each lap joint to hold Lexan in place.
Use Lexan plastic as it is more durable and more sun resistant than plexiglass.
Here's an example of other items we used to make these frames for. This poster measures 12 x 14. Most shops that make plastic items or sell plastics could make you a plate cover while you wait. Very easy to do.
What's neat about is that it looks invisible and there's no "frame" to hide the poster.
Plastic strip heater info here:
https://www.google.com/search?q=plas...hrome&ie=UTF-8
Old 11-28-2020, 07:50 PM   #8
Kube
Kube's Avatar
Kevin, Search "adjustable license plate frame" on eBay. There's a number of them for sale that will work fine for your particular needs. Plus, many appear to be era correct.
Old 11-29-2020, 10:33 AM   #9
51504bat
51504bat's Avatar
Don't know about New Mexico but in California plastic covers are illegal. Is it enforced? Not all that much but it can and has resulted in tickets, either fix it or pay the fine ones.
