Old 05-16-2011, 06:18 PM   #1
lotsagas4u
Default Vinegar cleanout?
Decided on running straight vinegar in my 8BA last week. I left it in for several days, running and driving it several times to reach operating temps of 160 to 170 degrees. Drained it this afternoon and flushed it well. The drivers side head cleaned out very well, the right side head was not as well. The vinegar was very red stained with oily blobs floating in it. I plugged the water pumps and flushed from the top of the head (thermostat housing removed) until water ran clear. How much baking soda would you use in each head to neutralize the vinegar? The engine runs well and uses very little oil. Thought's
lotsagas4u is offline   Reply With Quote
Old 05-17-2011, 07:02 AM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Vinegar cleanout?
Send a pm to Cecil Polan and ask him that same question. I remember reading a post he made on the old Fordbarn and an article he wrote in our EFV8C/A RG36 newsletter on how to do a vinegar clean out.
John
Old 05-17-2011, 08:01 AM   #3
saints
saints's Avatar
then post resualts as I would like to try this as well
FLATHEAD ADDICT
saints is offline   Reply With Quote
Old 05-17-2011, 08:33 AM   #4
lotsagas4u
I should have left it in for at least a week, another idea is simple green. They use it all the time at my local ford dealer for removing oil and crud from the 6.0 diesel engines. It would remove the brown soot left in the heads I bet.
Old 05-17-2011, 11:15 AM   #5
Russ/40
Russ/40's Avatar
A good flush is all you need. No need to neutralize the vinager. If your using tap water, especially in the west, the pH is enough to neutralize it.
Russ/40 is offline   Reply With Quote
Old 05-17-2011, 11:44 AM   #6
OhioRick
OhioRick's Avatar
I run 100% vinegar when cleaning out an engine. I too run it for a week. I had one that took three times to finally clean.
OhioRick is offline   Reply With Quote
Old 05-18-2011, 02:31 AM   #7
52merc
52merc's Avatar
are you talking white vinegar?
52merc is offline   Reply With Quote
Old 05-18-2011, 05:58 AM   #8
31chevy
31chevy's Avatar
What percentage of simple green to water is best? Thank you in advance.
31chevy is offline   Reply With Quote
Old 05-18-2011, 08:27 AM   #9
Cecil/WV
Cecil/WV's Avatar
Yes, just the vinegar you get at the food store. I left mine in for about 2 weeks and only flushed it with water and really got the crud out. Here's a pic of what I drained out.
Cecil/WV is offline   Reply With Quote
Old 05-18-2011, 08:32 AM   #10
Clem Clement
Clem Clement's Avatar
Ihave a repo aluminum radiator. Vinegar OK for aluminum?
Clem Clement is offline   Reply With Quote
Old 05-18-2011, 09:17 AM   #11
Flathead Red
Flathead Red's Avatar
Can this be done to any engine?
Red
Far and away the best prize that life has to offer is the chance to work hard at work worth doing....Teddt Roosevelt
Flathead Red is offline   Reply With Quote
Old 05-18-2011, 10:09 AM   #12
Cecil/WV
Cecil/WV's Avatar
We use vinegar to clean household items like faucets, nozzles, etc. and it won't hurt the finish on chrome, stainless or steel. It might discolor polished cylinder walls if on too long.
Old 05-18-2011, 11:13 AM   #13
FL&WVMIKE
FL&WVMIKE's Avatar
I sure would nuetralize it. It is an acid, which you would not want to blow out onto your paint. It would, probably, spot it.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 05-18-2011, 11:31 AM   #14
fordcragar
fordcragar's Avatar
I use vinegar to clean rust off of sheet metal all of the time. Soak the parts for about three days, then rinse of with a hose, then neutralize with soap and water; which eliminates the flash rust. I would imagine that if you put coolant into the system after flushing, it would do the same to neutralize any acid.
fordcragar is offline   Reply With Quote
Thread Tools
Display Modes
