12-18-2015, 01:11 PM | #1 |
Radiator shell removal Accomplished!!!
In a previous post I asked some advice on removing a radiator shell from a late 29 Tudor Sedan.
It turned out that the shell was indeed soldered to the neck of the radiator. Heating the neck with a propane torch, and with two wooden wedges placed between the radiator and the shell, a couple of blows with a hammer driving the wedges inwards popped the shell right off. Now the question becomes, do you think that after re-chroming the shell will I need to re-solder the thing or not? Thanks to all that offered their help on this problem. I hope to post photos as soon as I can figure out how to do it. |
12-18-2015, 01:19 PM | #2 |
Re: Radiator shell removal Accomplished!!!
The shell should be nickel plated rather than chrome. Nickel has such a nice golden hue.
I wouldn't solder it to the neck. |
12-18-2015, 01:38 PM | #3 |
If the previous owner soldered the shell to the radiator he was putting a band aid on some other problem, fix it right. Another problem if you tried to solder it after it was plated you would discolor the plating.
Charlie Stephens |
12-18-2015, 01:56 PM | #4 |
Nickel would be correct, not chrome.
12-18-2015, 03:53 PM | #5 |
Nickel it will be.. Thanks
12-18-2015, 08:27 PM | #6 |
12-18-2015, 11:14 PM | #7 |
Pay attention to this advice. it is right on the money! Wayne
